View Poll Results: What could it be
Relay
0%
Not a proper ground
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
My civic won’t turn on
Old Feb 16, 2022
rickyjanzen's Avatar
rickyjanzen is an unknown quantity at this point
I try to start my civic and I hear one click when I turn over the key. The battery is good same with the starter. Any ideas on what it could be?
Old Feb 16, 2022
FRSam's Avatar
Click Here
Re: My civic won’t turn on
Post a video. The way you described it, it's anything from a bad relay to a locked up engine.
Old Feb 16, 2022
Here is a video of it.
File Type: mov
Old Feb 16, 2022
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Bad brake pedal position switch or its circuit? This and the battery, starting and charging system checks.
Old Feb 16, 2022
why do you know starter is good, out of curiosity?
it's common during winter for rodents to get under the hood (warmer for them) and start chewing wires)
Also, check if timing belt is OK first. If it snapped, your pistons are touching the valves and if you try to force, it will bend the valves.
Old Feb 16, 2022
Colin42's Avatar
Check battery and starter connections
Thesuperboy
Nov 22, 2017 09:08 AM
Paulie
May 3, 2012 03:05 AM
breault5
Dec 30, 2007 12:34 PM
rcamp9
Jul 15, 2007 12:31 AM
zane03
Jan 14, 2005 01:47 PM
