not the usual speed sensor question connector damage [solved]
Old Jan 21, 2023
mkeschinger's Avatar
mkeschinger is an unknown quantity at this point
Hi!
I bought a beater 2001 honda civic ex 5 speed to fix up.
The speed sensor on the rt front wheel pops a code for an open circuit.
Got a new speed sensor, of course, and went to put it in.
Found the problem.
The connector it connects to from the car- one of the wires is pulled out.
I'd like to splice in a new connector there.
To be clear, the new part is fine-it's the connector IT connects to.
I've tried to find a part number and can't.
Does anyone know what it is? Is it even possible to replace that connector? Is there a special harness it connects to?
Or am I cutting the connect off and taking the one off of the sensor wire and just soldering it together or using different connectors..
help!
I appreciate your time. I am sure this will be one of many questions I have- after searching the forum of course.
In this case, I don't even know what part to ask for. I use HPN for a lot of my parts and tried to use their diagrams.
but again- only shows me the speed sensor- female side- as it were.
I need the male side from the harness.
Thanks again!
Old Jan 21, 2023
re: not the usual speed sensor question connector damage [solved]
I just saw that I posted this in the wrong year forum... Sorry about that.
Old Jan 21, 2023
You're good. We can move it for you no issue.
IMO, your best bet to replace a sensor pigtail like that is to snip one off at a junkyard/pick a part and polish off your soldering skills.
I'm almost certain they don't sell just that pigtail. You'd have to buy the whole wiring assembly. I think the closest you'd be able to buy the pigtail is finding the exact connector it uses, and a pack of pigtail wires. That is if they sell that connector by itself
https://www.hondaautomotiveparts.com...-connectors-fr
Old Jan 21, 2023
Colin42's Avatar
With it being a sensor wire it might be shielded (wrapped in tinfoil) or a twisted pair. Just try to make your repair match what should be there as close as possible
Old Jan 23, 2023
Thanks guys! After being reminded that I could find the part at a junkyard- thanks xriceboyx, I figured I'd give it a shot on repairing it. I cut the remaining wire just long enough to re-use it if I could get it fixed. They actually come apart rather easily and I was able to solder a wire to the actual pin, put it back together and solder it back to the harness... Worked like a charm! I should go to the junk yard, get one and do a how-to.
tott2692002
Electronics
Jan 8, 2022 08:21 PM
kye85
Transmission
Oct 14, 2020 12:29 PM
Boosted2k2
Jan 29, 2003 10:56 PM
LJ
Dec 1, 2002 03:15 PM
