Whoops, Might have blown my window motor
Old Nov 5, 2021
Millsy088's Avatar
Millsy088 is an unknown quantity at this point
Exclamation Whoops, Might have blown my window motor
Hi there, so basically i needed to remove my doorcard in the process of replacing my door lock actuator, which was a pain in its self, but my dumb*** forgot to disconnect the battery when taking off the door card, and after re installing everything (apart from the actuator as i need a new one) the window on that door no longer goes up or down, doesnt even make a sound, however the rest do just fine. any thoughts on how bad i screwed up / what might have gone wrong?
Old Nov 5, 2021
Millsy088's Avatar
Re: Whoops, Might have blown my window motor
Yeah so uhhhh it started working again. Can't say im complaining!
Old Nov 5, 2021
BrotatoChip's Avatar
Super Moderator
There's no reason you'd have to disconnect the battery to replace a door lock actuator. If it stops working again check for loose connections.
Old Nov 5, 2021
Colin42's Avatar
Broken wires in the door jamb
Old Nov 8, 2021
Millsy088's Avatar
yeah thats what i assumed, and i guess i was right, but its probably good practice to disconnect the battery any time i work on the electronics
Old Nov 8, 2021
Millsy088's Avatar
interestingly sometimes it goes up quite slowly and has a hard time getting all the way up, would that be a wiring thing? it seems to me like it could just be an old unreliable window motor?
Old Nov 9, 2021
Colin42's Avatar
Very common to have broken wires in the door jamb
Old Nov 16, 2021
danilo1's Avatar
danilo1 is an unknown quantity at this point
I've found it usefull to...
Spritz the Fuzzy fur Window channels every year or two with Silicone spray.
It really helps to get the windows to go up 'n down easily and smoothly.
Easy enough to try and it definitely will not hurt..
Old Nov 17, 2021
Millsy088's Avatar
Re: I've found it usefull to...
yeah thats actually a really good point, i guess it also wouldn't hurt to spray it on the rubber channels that guide the window down, next time i have the door panels off
nickrolando
20
Jul 19, 2012 09:27 PM
jberenyi
Mar 14, 2012 07:50 AM
gummi215
Jan 3, 2011 06:40 PM
mod5
Jun 25, 2009 03:17 PM
RedSuns
Jul 21, 2004 11:28 PM
