HELP! Power Windows and Door Locks not working 2001 Civic 4dr
Old Jan 3, 2011
gummi215's Avatar
gummi215 is an unknown quantity at this point
So recently my 2001 Honda Civic 4dr is slowly falling apart.
First, the passenger front window will no longer work and stays open about 1/2 inch. So i get that noise when I drive on the freeway and rain water when it rains. Someone told me to get a window regulator assembly..will that solve the problem?
Second, the power door locks one by one stopped working. The only one that works still is the rear right side. I was reading the forums and I keep reading about the actuators. Would i need to replace it for every single door? Or just the driver side one?
Any help would be greatly appreciated. Thanks
Old Jan 3, 2011
Re: HELP! Power Windows and Door Locks not working 2001 Civic 4dr
yeah each door has an actuator. if you do the power lock and dont hear the motor in the door panel, its prolly bad. same with window. the regulator and motor controls the window movement and also keeps the window held up. if its cracked, it can cause the window to slide open a bit.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
roverben
Jan 21, 2019 05:16 PM
mattdoc
Mar 14, 2017 12:10 PM
darwin-t
Apr 18, 2015 09:29 PM
lilbluecivic
Nov 7, 2001 06:49 PM
