O2 Sensor ECU Swap
Old Jun 1, 2020
tettingtravis's Avatar
tettingtravis is an unknown quantity at this point
O2 Sensor ECU Swap
Super unknown condition 2002 Civic EX with a d17a1 bottom end and d17a2 head. P0141 with no ground to downstream sensor. I check the ECU and a14 and a25 wires are literally not in the harness and nowhere to be seen (not clipped, someone removed the actual female pin?). e2 and e6 are wired, but have been clipped and reconnected with a heat shrink. Question: if this car had an aftermarket ecu, is there a process that involves moving a14 and a25 somewhere? Those wires should come from the O2 sensor, to the #4 dash fuse, and then to a15 and a25 right? Anyone have experience with this and know where those wires might be?
Old Jun 2, 2020
BrotatoChip's Avatar
Super Moderator
Re: O2 Sensor ECU Swap
That is not what my schematic shows at all, I don't show A14 or A25 being used for anything.
Pin E3 is connected to a shield around the white/red wire. It also runs to "L" at the bottom which just is a ground in the OBD2 connector. The Black/orange wire going to "D" at the bottom goes to fuse 1 in the under-dash fuse box.
Old Jun 2, 2020
I was going off of this post: https://www.civicforums.com/forums/1...g-diagram.html
Old Jun 2, 2020
Super Moderator
Ah I see. In that list you can also see the pins I referenced are also for O2 sensor. The pins you were going by are for a different overseas model.
Old Jun 2, 2020
Great! I checked for continuity and everything looks good from the o2 connector to the ecu connector. However, still receiving the p0141. It seems I can't get a ground at the black/white e6 at the ECU. If I disconnect the E connector and test the ground at pin 6, nothing. Time for a new ECU?
Old Jun 2, 2020
Super Moderator
Pin E6 is the heater control, the PCM supplies the ground when it wants the O2 heater on. At the O2 connector do you also have battery power on the black/orange? Also, measure resistance across the black/orange and black/white but on the sensor side. This will verify the heater coil in the sensor is okay. I can't tell you for sure what you'll see here but it should be less than 10 ohms I imagine.
Old Jun 2, 2020
Ohms are good (new denso sensor) and with KOEO I get 12v on Black/orange.
Old Jun 3, 2020
Super Moderator
I finally looked in the service manual, you should see 10-40 ohms across the heater coil in the sensor.
I have also attached the troubleshooting steps for the code.
File Type: pdf
Old Jun 3, 2020
Amazing man. Thank you. I get a full 12v from e6 to a5, so I guess it means a new ECU. I'm guessing it was from a short in the O2 wire?
-Travis
familyguy
Sep 13, 2025 08:19 PM
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
familyguy
Engine Swaps
Nov 26, 2012 02:59 PM
Toaster
Nov 10, 2006 08:04 PM
cdmx
Oct 23, 2004 01:33 AM
