Passenger headlight only appears under certain circumstances
Old Dec 12, 2023
Luciferr94's Avatar
Luciferr94 is an unknown quantity at this point
So, my passenger low beam light will be visibly shining on things that I am close to, but if I were to say get on the road, it looks like only one headlight is on.
This problem seems to be isolated to the low beam, high beams look fine
Old Dec 12, 2023
Re: Passenger headlight only appears under certain circumstances
could be an aiming issue if it seems like you only got one beam showing on the road. Park about 25 feet from a wall and see what the beam pattern looks like. What I suspect is your passenger headlight is pointing hella far upwards
https://www.civicforums.com/forums/1...k-warning.html
Old Dec 13, 2023
Luciferr94's Avatar
My passenger headlight wasn't visible at all on the wall, seeming like it was just so much dimmer than the driver side that it appeared to be off. I did get out and look at the headlights from the front and the passenger one did appear substantially dimmer than the driver side
Old Dec 13, 2023
lens clear? bulb end of life?
Old Dec 13, 2023
Luciferr94's Avatar
The lens isn't polished or anything, but it's pretty clear.
I just recently bought the car so I don't know how long ago the bulbs were replaced, can they go out at significantly different rates like this
Old Dec 14, 2023
if you just bought the car, how can you say different rates...
the car is past 20 years old.
life expectancy is just estimates. Does every animal dies suddenly at same age?
Old Dec 14, 2023
Luciferr94's Avatar
To be honest, I was mainly just tired and didn't think about the fact that there is no reason that both bulbs would have even had to have been replaced at the same time so it would make perfect sense for them to be on different life cycles, even aside from the fact that things don't die at the same time
Old Dec 14, 2023
Colin42's Avatar
Good practice is to replace the bulbs in pairs, lots of people dont do this
Old Dec 14, 2023
i buy a pair, but change when they are getting weak (or burn, sometimes they don't get weak, simply go...)
Old Dec 14, 2023
quick/free test would be to swap the bulbs. You know one is working proper and the other isn't. If it's a bulb problem, then the problem will follow the swap. If it's electrical, then it'll stay on the same side.
CIVINATION
21
Mar 27, 2016 02:20 PM
D16Z6_owner
Buy, Sell, & Trade - Archive
Jan 12, 2008 08:37 PM
Jasdip
29
Apr 22, 2007 08:01 PM
rhevo2k1
Nov 6, 2003 09:54 PM
Mr.Modify
Oct 17, 2003 02:27 AM
