Interior trim piece question
Old Mar 6, 2022
SKcivic's Avatar
SKcivic is a jewel in the roughSKcivic is a jewel in the roughSKcivic is a jewel in the rough
I have a 2002 Honda Civic EX Coupe, automatic, dark gray interior (USA spec.)
I’m installing an aftermarket fog light kit. I planned to put the switch next to the cigarette lighter / 12 volt power source. My Civic has two vertical blank switch panels, just to the left of the 12 volt power source / cigarette lighter. This is where I planned to install the factory looking aftermarket fog light switch.
Apparently, I need a single switch panel, where the single switch is mounted horizontally, next to the 12 volt power source / cigarette lighter.
Can someone point me in the correct direction for what year (7th generation), trim / specification level that I should be looking for, so as I can buy the needed part?
Old Mar 6, 2022
Colin42's Avatar
Re: Interior trim piece question
Pictures?
Old Mar 7, 2022
BrotatoChip's Avatar
Super Moderator
I had the same issue. All the aftermarket fog light kits give you a switch the wrong size. The switch would fit in the slots to the left of the steering wheel but because you have an EX they are all already taken (cruise main and sunroof). I think the proper sized trim piece you're talking about was a 2001 thing maybe. It would be easiest to go walk around in a junkyard to find the right one.
On mine I originally modified the stock trim piece to accommodate the larger switch. The switch that came with my kit looked stupid cheap so I actually wired it up to another cruise main switch. Then one day in the junkyard I found an OEM fog light switch. Replaced the trim piece with another stock one and wired in the OEM switch instead.
Old Mar 11, 2022
gatrhumpy1's Avatar
gatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of lightgatrhumpy1 is a glorious beacon of light
I have an OEM fog light switch for sale on the For Sale section. Check it out.
Zigroyd
Jun 17, 2009 09:59 PM
cwo715
Jul 11, 2006 03:11 AM
gearbox
Sep 26, 2003 11:03 PM
aldini
Mar 10, 2002 10:36 AM
Diznavis
39
Feb 1, 2002 01:14 PM
