Electrical issue…I’m stumped lol
Old Aug 11, 2023
rhearty's Avatar
rhearty is an unknown quantity at this point
Hey guys
i have an 05 civic sedan lx sport I’m trying to fix. Car intermittently won’t start. Replaced the battery, didn’t fix the issue. Replaced the alternator, thought I fixed the issue, but again car intermittently won’t start due to partially drained battery I believe (car dash lights still came on but not enough battery power to start the car). I’m thinking there may be a parasitic draw on the battery? My multi meter reads 14.4 volts when I have the car running so I do believe the alternator is charging the battery
adequately. the only thing “wrong” with the car right now from what I can tell is that the DRL light is on on the dash, drl’s do not work but it looks like both headlights and high beams stil work. I checked fuses for the drl’s and I believe they are fine. Not an electrical guy so I’m stumped. Any suggestions are greatly appreciated. Thanks
ryan
Old Aug 11, 2023
Re: Electrical issue…I’m stumped lol
check parasitic draws using multimeter on the fuse boxes
alternator must be OEM, hondas no like aftermarket alternators ans sensors
remove, clean and check grounds
Old Aug 11, 2023
rhearty's Avatar
ok thanks for the info. So even a brand new aftermarket alternator would cause these issues?
Old Aug 11, 2023
why, we don't know
but do check for parasitic draws, lots of rodents chewing wires incidents
Old Aug 11, 2023
Serious question, have you tried smacking the ish out of the starter?
Old Aug 12, 2023
rhearty's Avatar
nope haven’t tried that yet. But the car starts up every time I charge the battery so I’d be surprised if it was the starter?
Old Aug 12, 2023
Fair enough. Still wouldn't hurt to try it. It's a free check that takes all of 5 minutes.
I had intermittent starting issues on my 2002 (never paid attention to the correlation between a jump start vs non-jump start) and had zero starting issues after I smacked the starter in a parking lot. I just used the business end of a 12" 3/8 socket extension (since I always have a full tool kit in my car), lined it up with the starter solenoid, and a couple good downward thrusts.
Old Aug 12, 2023
Caveman
Old Aug 12, 2023
Hey man.. if it's stupid and it works, it ain't stupid. lol
You know I always go for the free/cheap fixes or tests first
Old Aug 21, 2023
emich's Avatar
emich is an unknown quantity at this point
Obviously the problem is low power from the battery. Either the battery is weak and/or parasitic draw. Disconnect the battery overnight. if it start in the morning the battery is fine.
Old Sep 4, 2023
rhearty's Avatar
Ok so quick update, I was doing a parasitic draw test with multimeter and found that the #9 10amp fuse labelled “Back up” (under the hood fuse box) was at least drawing some of the power from the battery. Anyone know what this powers or anyone know where I can look at a wiring diagram? Thanks
ryan
Old Sep 5, 2023
BrotatoChip's Avatar
Super Moderator
Old Sep 5, 2023
you sure that's under hood and not cabin fuse box @BrotatoChip ?
If it's labelled backup, I'm thinking it's the whole reverse light system. I'm thinking stuck reverse switch or short in tail light wiring.
Old Sep 6, 2023
Super Moderator
How dare you question me After reading all the components I convinced myself I was wrong, but....
Old Sep 6, 2023
I'll be damned. All of those components with no other context made me think that Honda would put all that on a circuit fused inside the cabin. I just confirmed that with another forum post where some other dude had a parasitic draw on that same fuse (no resolution was posted, otherwise I'd link it)
@rhearty what was the amp draw from that circuit when you checked it?
ig7thgen
Feb 18, 2016 12:57 AM
airognol
Mar 25, 2013 09:55 AM
Goonth
Feb 21, 2011 05:22 PM
Glenn...
Jan 30, 2011 02:48 AM
screen-name
Aug 15, 2010 07:53 PM
