All power door locks not functional. Fuses OK
Old Mar 23, 2022
BlazeCode's Avatar
BlazeCode is an unknown quantity at this point
Hello! I have a 2004 Honda Civic Si Hatchback. Ive got everything on it working properly except for the power door locks now.
So its a two door. When I hit the locking switch or use the key fob it does lock and unlock the trunk. However, the two doors do not move at all unless I manually push/pull their lock-****-things at the top of the door.
There is a relay that sounds like it clicks 4 times under the dash when I do this. Im assuming its 1 click on 1 click off and does it for each door. But like I said, nothing happens.
I checked the under hood fuses 16 and 9. Both are good after doing both visual inspection and multimeter test on each.
Is there any other fuses to check? I cant imagine BOTH actuators went out, right?
Any info is appreciated!
Old Mar 23, 2022
BrotatoChip's Avatar
Super Moderator
Re: All power door locks not functional. Fuses OK
It would be worth your time to check the lock actuators. They are all powered from the same fuses, separate relays though. Unplug the actuator and measure voltage across the two lines. +/- 12V when locking/unlocking.
Old Mar 23, 2022
BlazeCode's Avatar
i initially wanted to do that before posting. However, im fearful of damaging that plastic weatherproofing thing thats on the inside of the door. Im assuming the glue is hardened after all these years and ill have to cut it. How vital is that weatherproofing to the car door? Can I live without buying a new one if I tear it?
Old Mar 23, 2022
Colin42's Avatar
Use a razor to cut the glue, if the driver's actuator is bad it might not let the passenger door unlock
Maqcro
Exterior
Oct 12, 2021 04:33 PM
Aaron Anderson
Mar 22, 2017 12:50 PM
Otg02
May 9, 2014 03:24 PM
sunnydays
Mar 16, 2012 01:07 AM
BlueBullet
Sep 24, 2003 10:29 PM
