Power Door Locks Only Work Sporadically
Old Mar 15, 2012
sunnydays's Avatar
sunnydays is an unknown quantity at this point
Question Power Door Locks Only Work Sporadically
I have a four door automatic 2005 Civic EX. The door locks started acting up recently. At first, when I locked the doors (using the inside driver's door switch) all the doors locked except the right back door. It neither locked nor unlocked automatically. Then all the door locks began acting up. When I lock the doors, sometimes only one or two lock. Sometimes none lock. This is the case rather I am using the inside switch or the key fob from outside. Does anyone know what might be the cause? Thank you!
Old Mar 16, 2012
sl33pyriceboi's Avatar
Re: Power Door Locks Only Work Sporadically
your actuator is probably going to take a dumb. search the forums and you'll get a lot of info on it.
roverben
Jan 21, 2019 05:16 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
