Door locks [solved]
Old Sep 10, 2021
Maqcro's Avatar
Maqcro is an unknown quantity at this point
Door locks [solved]
I am having issues with the door locks. The key fob doesn’t work anymore to unlock the door. The switch inside the car doesn’t work either. I checked the 7.5a fuse under the steering wheel but it was good. Any ideas?
thanks
Old Sep 10, 2021
re: Door locks [solved]
check wires at door hinges.
Old Oct 6, 2021
Maqcro's Avatar
I checked the wiring at the driver door hinge and didn’t see any wiring issues.
checked door lock switch - all good
picked up a door lock module to try and replace - no change
checked power on door lock pins - Battery voltage on all 3 pins.
- must be a short somewhere… any ideas other than driver door hinge?
thanks.
Old Oct 6, 2021
thanks.
you will need to take it apart and check - aside form the most common issue at hinges, could be anywhere.
Old Oct 12, 2021
Maqcro's Avatar
removed entire door and checked wiring at driver door hinge. One broken wire. Soldered a new piece of wire and shrink tube both splices - works like new again!
thanks!
Marty Vargo
Electrical
Mar 17, 2021 07:34 PM
h4ldol
Jun 30, 2015 06:07 PM
TechMonkey
Jul 5, 2014 05:05 PM
streetglower
Jul 15, 2004 10:48 PM
thirdhonda
General 7th Gen
Jun 23, 2002 08:33 PM
