Power Door Locks and Windows
Old Mar 22, 2017
Aaron Anderson's Avatar
Aaron Anderson is an unknown quantity at this point
The power door locks on my 2015 Civic Sedan are not working. When I hit the switch I hear the locks trying to work but they don't lock or unlock. Same when I manually push down the drivers door lock **** or use the remote unlock. They all stopped working at the same time.
I also have a problem with the drivers door window which intermittently does not work and which seems to be more often. I am not sure if these issues are related but they both started about 6 months ago.
I have checked the fuses and they are good. I plan to tear off the panel on the drivers door this weekend and see what I can find. Any tips on what is the likely problem would be appreciated.
Old Mar 22, 2017
CraigW's Avatar
Re: Power Door Locks and Windows
Under 36k miles ? Take it in.
