2004 civic Ex headlight alert...won’t shut off
Old Dec 12, 2020
Devenob's Avatar
Devenob is an unknown quantity at this point
A couple weeks ago I noticed when I remove my keys and open the door the alarm saying the headlights are left on comes on. If I shut the door it shuts off, if I put the keys back in the ignition it gives me the keys in ignition beep. The headlights are not left on, I left the door open the other day and pulled fuses, neither headlight fuse shut it off when pulled. But pulled the ignition fuse DID shut it off. What do you guys think it could be? I can’t find a similar issue anywhere online
Old Dec 13, 2020
Wankenstein's Avatar
Re: 2004 civic Ex headlight alert...won’t shut off
Try one of these fixes yet? https://www.google.com/search?client...e-gws-wiz-serp
Old Dec 13, 2020
Devenob's Avatar
Originally Posted by HR Puffinblunts
which would you suggest, it seems like everyone’s issue is the head light chime stops works, mine won’t shut off
Old Dec 14, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Watch the first Youtube one on the driver's door switch. These switches can become mangled - especially by mistake if a seatbelt buckle gets caught between the door and the switch as you slam it closed. In your case, since the buzzer does not work, the switch would be stuck on/broken and think the door is always open.
Old Dec 14, 2020
Devenob's Avatar
so the issue of the headlight on alarm is only when the door is open. Once I shut the door the alarm shuts off. If I put the key in the ignition and open the door I get the key left in chime. If I pull the key and open the door I get the headlight alarm. The lights are not on, and the only way I’ve found to get the alarm to stop is to pull the ignition fuse but obv I can’t leave it out
cwmoore9
Jul 7, 2017 04:05 PM
Bradygc
Lighting
Jun 13, 2017 10:58 PM
t.c.v
Aug 24, 2013 01:42 PM
mfskarphedin
Aug 15, 2012 04:02 PM
meombrian
Nov 1, 2006 08:28 PM
