2004 Civic stereo and cigarette lighter not working
Old Sep 25, 2020
BradRun's Avatar
BradRun is an unknown quantity at this point
Greetings,
I've checked fuse #8 under the steering wheel and it is fine. The stereo has power, all controls work, but no sound.
Suggestions?
Thanks! Brad
Old Sep 26, 2020
GolNat's Avatar
Prelude Owner
Re: 2004 Civic stereo and cigarette lighter not working
Check the fuses under the hood.
There is a back up fuse that you need to check also.
If all the fuses check out okay then your radio might be bad.
Old Sep 26, 2020
BradRun's Avatar
Thx.
I did check fuse under the hood, forgot to mention that. Fuse #14, "option".
But what about the cigarette lighter?
Thx! B
Old Sep 26, 2020
mac25's Avatar
Dr Krieger of Modification
Since they're in the same location, they may share a circuit.
Do you have the radio circuit diagram?
Old Sep 26, 2020
BradRun's Avatar
I have the fuse box diagram via YouTube:
Old Sep 26, 2020
leok99's Avatar
leok99 is an unknown quantity at this point
12V outlet is under dash fuse #18, accessory power socket.
Old Sep 26, 2020
BradRun's Avatar
Thanks. Checked the fuse on that too. Fuse is good. Just removed shifting boot and cigarette lighter assembly.
Old Sep 26, 2020
BradRun's Avatar
Duh on me. Aux power works - tested at 12v. My testing units, a phone charger wasn't long enough to reach the power, and my powered flashlight's bulb was burnt out. Arrgghh.
So tomorrow, pulling the stereo. As earlier posts suggested, I'm betting stereo is bad.
Thanks everyone for the suggestions. Appreciated.
I'll report back with radio/CD player unit update.
Old Sep 26, 2020
Do yourself a favor and grab you a $30 multimeter at home depot or lowes. Quite useful for more than just this one instance
I got me a $30 one at home depot a while back, and it's done me well. I replaced it with a Fluke brand one my step dad gave me, and been using that since, well, Fluke brand and they're quite expensive. lol
Old Sep 26, 2020
BradRun's Avatar
Thx!
Old Sep 28, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
If this is an after-market audio unit, then problems have occurred when the Illumination wire from the unit is connected to the vehicle - solution is to not connect this.
There is another ACC Power Socket fuse: #18 (15A) in the Under-Dash Fuse Relay/Box.
You must have a Coupe Civic as you are missing the rear power window fuses.
Old Sep 28, 2020
BradRun's Avatar
Thx. This is stock audio unit. Both under steering wheel and under hood fuses were good. Yep, it's a coupe.
Zardoz
Aug 10, 2016 08:19 AM
MaxMark
Mar 19, 2015 09:09 PM
coachdink
Nov 21, 2008 11:13 AM
tictac
Jul 12, 2004 06:57 PM
Jas88
Jul 24, 2003 07:27 PM
