View Full Version : Engine
- Overheating randomly
- Need some help
- Yet another failed start thread 00 EX MT
- d16y8 crank no start. has fuel has spark.
- 96 civic ex losing power! Vtec hessitation!
- 96 civic smog question?
- Any good places to buy hoses?
- help me identify what head i have
- CEL on with p0170 and p0171 codes
- Blown headgasket?
- 2000 Civic EX no start problem. [solved]
- Duct tape in iacv
- Head bolt over torque what now
- White smoke + running rich SOLVED
- Loose harmonic balancer replaced and now won’t crank
- Aluminum Shavings removal
- Indefatigable P1457
- 2000 Honda Civic OEM Thermostat Rating
- Power loss/hesitation P1362 code [solved]
- 11 codes from computer
- Straight pipe exhaust
- trouble starting...crank but won't start
- 99 Civic EX 1.6 p0355 code help!!!!
- 98 civic coupe idle up and down, sounds like it might misfire, and weird popping nois
- d16y5 block with d16y8 head and y8 manifold need help!?!?!
- 1996 Honda Civic Throwing P0452 Code
- 97 Honda civic crank no spark
- 2000 Civic LE: Copper plugs?
- D16Y8 Valve Springs same in D17A??
- Rebuilt engine not running cant fighter it out...
- 97 civic mystery misfire code
- 02 sensor p0132 code
- What’s wrong???
- D16y8 knocking noise
- P0420 code, already replaced cat & o2 sensor
- 2000 civic hx knocking cel on
- Sputtering, popping and cel, boosted civic
- Surging Issue cleared by engine restart
- HELP unknown sensor/plug
- 96 Honda civic ex Sputters at 4000 Rpm
- idle surges after sitting for a few minutes/white spark plugs
- Need help diagnosing noise
- I had a bit of a scary moment on the highway today (stuck WOT throttle, 2000 civic)
- Air-ish sound behind dash
- Overheating
- p1259 code (solenoid and connectors replaced)
- Busted head bolt fixes and if it relates to leaking coolant
- Intake manifold bracket bolt
- NGK VS Taylor Cable
- Looking for a place to buy a decent reman d16y7
- D16y7 misfire, rough idle, oil in radiator,
- B18b Swap idle surging and shuts off when in gear
- D16 Oil Gallery Plug Source
- odd starting problems
- Civic rebuild mechanic quote
- Check engine when car heats up
- Click no start after starter replace
- Stuttering while accelerating
- Warped Head?
- Idle surge and P1337
- 2000 honda civic LX idle/engine lugging
- 96 civic mini swap issues
- 98 civic, no spark, no obd2 code
- 99 Honda Civic dx Exhaust manifold glowing red
- Ran out of gas!
- Sputtering Civic
- Blue devil flush
- Swamped in swap
- power steering pump
- Crank No-Start. Compression issue?
- Car drives around very well for a while, and then dies.
- Is an OBD reader useful if you don't have your check engine light on?
- Will STA-BIL effect my smog (emissions) test?
- Distributor timing
- No start after changing rotor and distributor cap
- Engine rattle during acceleration
- Starting Issues
- 99 Civic overheat
- 2000 honda civic ex
- Engine appears to be seized after transmission work, why?
- 2000 civic radiator fan
- 1999 Honda Civic DX Downstream 02 Sensor Malfunction / P0141
- New member/rough civic Lx
- Swapping a new B16Y7
- 1999 Honda Civic DX High (Positive) Fuel Trim At Idle
- Engine Surging while holding Acceleration
- Civic idles fine, when I rev it and attempt to rev it again it cuts out backfires
- 1998 honda civic hatchback 1.6l d16y7 automatic transmission P0335 code
- Coolant leak
- 96 1.6L starts and dies immediately
- Overheating issue solved by AlloyWorks slim fan and shroud
- Running issues
- Help! Engine making grinding noises!
- 00 civic ex no start no crank
- Loud ticking noise from engine
- P0505 (Idle Air Control Valve) Keeps popping up, despite being replaced 4x
- Weird acceleration issue
- Upstream 02 sensor on DI6Y8
- 98 civic lx oil disappearing randomly
- 99 honda civic ex
- Having overheating problems
- RPM’s fluctuate when AC on, blows hot idle, cold driving
- My em1 is throwing a P0452 code
- Bad Idle
- New to me 98 Civic Cx. Crank wont Run.
- Help identifying / replacing damaged connector
- 2000 civic LX Assembled in Japan exhaust
- 98 civic dx hb tried to overheat with ac
- d16y7 turbo, stock engine limits.
- 2000 civic si seems to run rich
- AC Causing Engine suicide
- Very strange problem
- honda civic 1 wire to 4 wire o2 sensor conversion (not working)
- P1361 Confusion
- 96 Civic DX exhaust literally broke into 2. Need help figuring out a replacement
- Honda civic p06 ECU Q31 burned.
- Civic fan not coming on
- 99 Civic EX LS swap won't start
- Running rich after filling up tank
- Rouge bolt under valve cover
- B16A2 Timing Belt
- b16 pcv
- 99 civic crank no start in the morning
- Engine leak
- NEED HELP Distributor to Coilpack Conversion on a D14 engine
- 99 civic EX knock code
- 1996 Honda civic low rpm and stall
- 1996 honda civic VTEC and speedo not working
- Weak acceleration
- Loss of Heat in cabin.
- spun rod bearing
- Are CNG and Gas fuel injectors different? Can electrical damage be fixed?
- Low idle and bogging issues, Codes 14 & 21
- P0420 and steam coming off exhaust manifold heat shield
- Starter/Solenoid
- 98 Honda Civic will start then won't.
- 1996 Civic D16Y7 sputter on acceleration
- 97 Civic - Will not start - help please!
- Check Engine Light
- Help! Civic crank no start
- D16Y8 hits revlimiter at 5,000 rpm
- 1998 Civic D16Y7 Idle Surging and stumbling acceleration.
- 97 Civic Cranks No start
- Please help!
- Cranks but won’t start after head gasket replacement
- Sluggish Start; weak acceleration
- Little rubber/paper piece under Reservoir Cap, how to replace?
- cylinder 4 ticking noise
- 00 Civic Ex Crank no spark no start
- Oil leak on an unknown valve
- My RPM’s drop in idle, as well hesitate/jerks when car driven
- catalytic converter problems
- Honda Civic 1998 LX Overheated once, then not?
- Rear cam seal
- thermostat rusted or sheared?
- Help... 98 civic cranks, fires, dies....
- D16y8 revving up and down, higher then normal idle
- New here please help.
- Camshaft caps 1 and 5 that bolt down cam
- 97 civic overheating
- D16A cylinder 2 misfire
- Was my timing belt installed incorrectly?
- Slow idle and loss of gas mileage.
- D16Y7 , at a loss
- Questions on extracting snapped spark plug, and anything else I to do while I'm at it
- D15 Z7, engine shuts off when car slows down or comes to a stop
- 2000 EX Automatic High Idle
- 97 Lx died going up a hill
- 2000 Civic oil leak?
- New civic owner, oil and coolant leaks
- P0335 code on and won’t rev past 3500rpm
- Replacement timing belt brands not Genuine Honda
- Swapped dx with ex
- Timing
- Doesn’t accelerate under stress/pressure
- When driving on highway car with loose all acceleration power and stall
- Cylinders 2 & 3 dead?
- Bolt broke off in block for water pump
- P0325 knock sensor issues
- Help: What Is Causing This sound?
- 98 Civic dx sedan, oil on spark plug threads
- Rear main seal oil leak
- Vacuum Leak Test Where To Connect?
- 98 LX High Idle with p0122 code
- 97 honda civic won't start.
- How To Fix Leak From Engine Coolant Outlet Flange AKA Water Outlet?
- Need help with this civic will not start please!
- Temperature Gauge/Fan not working
- 97 Civic coupe EX project
- Crankshaft Pulley Bolt
- where does this go d16y5 head
- (FIXED) crank no start condition
- P0113 wont go away
- Intake Manifold Gains
- 2000 civic swinging rpm
- 99 Honda Civic EX 1.6 VTEC SOHC question
- 1999 Honda EX 1.6 SOHC intake question and comment
- Stalling
- New guy here.
- P1164 and P1163 Codes (1998 Honda Civic HX)
- Crank pulley install
- Cluster temp gauge spiking
- Long Block Options
- P1509 Code after months, dealership couldn't even figure it out.
- D16Y7 engine Compression test, question about readings also misfire CEL
- stumped help plz
- Car stalls while driving
- Rad fan turns on too late
- Car won't start when engine hot
- Oil pressure from breather box
- y8 mini me swap
- Front pipe gascket orientation
- 2003 Civic Hybrid Radiator Fan
- 97 EX misfire
- IACV Replacement
- Exhaust 'everything from the manifold out' parts?
- low compression Not sure what to do now
- 99 civic ex no crank issues
- Problems with spark
- 98 Civic EX - Erratic idle
- D16Y8 Compression test results. Bad?
- New head or resurface head?
- 2000 3-door Civic will only run for 2-3 minutes
- 1996 DX - Starting Issues
- '00 Civic TPS
- B18C1 in an EM1... having some fueling issues.
- CEL came on while driving...
- 1999 Civic LX radiator fan and AC issues
- D16Y7 Coolant in Cylinder 4 and Idle Urging
- 98 Civic D16Y8 Rad Fan not coming on
- Misfiring when up to temp
- Car won’t start
- 1997 d16y8 problems help please
- 2000 DX. Won’t crank. Horn blows when turning key.
- Intermittent Idle/Firing Issue
- 98 civic lx
- Need to know the specifics of a bolt holding the exhaust up
- Curious idle
- Bought a swapped '97...
- 95 civic fuel issue
- Headgasket problems
- 97 Civic threw a bunch of codes all of a sudden and speedo dead.
- Won't start when and after it rains
- Missing at idle only when warmed up
- Fuel tank question
- New (to me) 2000 Honda Civic EX - what is my engine code?
- Checking compression thru spark plug tubes
- Rough Idle 98 Honda Civic
- 96 Civic Only Overheats on Highway
- Hose diagram, help!
