99 civic ex no crank issues
Old Jun 11, 2019
wakamavrick's Avatar
wakamavrick is an unknown quantity at this point
So my starter went out before, i had to change it and it fixed the problem before.
My battery died the other night and i tried to jump it, wouldn't start.
well i had this issue before and it was fixed by loosening the hot wire off the battery for a few seconds and putting it back on, worked just fine untill my battery had died.
WELL, for some reason my blinker lights would come on, but not flash just be solid. But it would start, BUT they wouldn't turn off. Even removed the fuses.
So had to take the hot wire off of battery again, Put it back on, the lights weren't on but would not crank what so ever.
Just really confused.
Also last night it tried to start after i placed it back on, but it tried to crank forever then finally did but kinda puttered out. I tried it again and gave it some gas and it started up and stayed running.
Any help would be great, I love my lil car just has 137k miles on it and want to make it last. Any help ideas and thoughts would be very appreciated.
Last edited by wakamavrick; Jun 11, 2019 at 12:39 PM. Reason: Left off some info when trying to add tags.,
Old Jun 11, 2019
Re: 99 civic ex no crank issues
And if it helps its an automatic as well.
Old Jun 11, 2019
After seeing a few other post, The only codes i were receiving before anything happened was for the catalytic converter. If anyone sees this and thinks i may have left anything out just ask.
Also its a new battery and starter both about 2 months old.
Old Jun 11, 2019
mac25's Avatar
Dr Krieger of Modification
Sounds like a short/multiple short circuits, since the turn signals are getting power when they shouldn't.
Start with a general check for
-fuses
-grounds
-relays
Then trace the signal light circuit and find out what is causing the issue there.
If you're lucky the signal lights are draining the charging system, and with that issue resolved it will jump start.
Old Jun 11, 2019
i did check all the fuses. and even that wouldnt fet my blinkers to go off.
i dont know a whole lot about cars but my buddy said hed help.me one day.
i did get it to start this morning no issue i just dont understand why it does that at times
jruth85
Engine start problems
Oct 9, 2019 06:22 AM
halo5ive
Mar 6, 2018 01:06 PM
rockey g
17
Feb 6, 2017 07:45 PM
01silverHonda
Jul 11, 2013 10:06 PM
