- D16y8 Oil pump/seals replacement
- crankshaft bolt removal (your techniques)
- idle/surge/bogging (lots of info/pics)
- 97 civic lx AT issues
- Fuel line replacement
- Crank no start '00 ex manual
- D16Y7 Intake/Vacuum Leak (PLEASE HELP!)
- 97 civic random idle problem+stalling
- 00 ex civix d16y8
- Unknown issue with 1998 Civic Dx
- Stalls on the road or doesn't start at all when warm
- 2000 EX multiple misfires returns after parts replacement. Twice.
- Burning Oil issue on 2000 EM1
- Radiator fan?
- 2000 civic ex (d16y8) idle problems
- Idling and driving problems
- Check Engine Light
- Honda Hesitation help!
- 98 civic ex won't start after replacing crankshaft sensor!!
- Problems with Code P0505
- 97 civic that Boggs down and sputters like it wants to die
- Rocker Arms extremely tight on valve please help
- 1997 Civic Dx...Died while driving...wouldn't start...fixed...starts...now sluggish!
- 98 Civic EX Knock Sensor
- How to change piston rings?!?
- 1999 Honda civic Idling problem. Please help
- 2000 LX - Exhaust Manifold replacement witout the cat
- 2000 civic BAD Bucking!! HELP
- Question - Changing valve seals
- Will turn over, but won't start
- ENG DIES WHEN YOU RELEASE GAS PEDAL on 97 civic
- 1996 Civic LX Engine Mystery
- Engine light 2000 Honda Civic Ex
- 99' civic
- 95 coupe ls swap help
- no spark
- Oil leak
- fuel sending unit/tank questions
- Drain plug leaking after oil change
- Clogged catalytic converter
- 1999 Honda Civic will not start
- I have a modified 98 ex and need serious help.
- no spark no fuel 93 ex d16vtec help please
- Warm start problem
- 2000 Civic Ek Choking Problems
- 99 Civic with 3 fault codes, P1298, P0135, P0141
- Engine vibrates and jerks when my civic idles
- Oil in coolant reservoir/using oil - 99 Civic EX
- Ground Wire Between ECM and EVAP Purge Control Solenoid
- 97 Honda civic failed CLT test, not a head gasket
- flooding problems please help
- check engine light prob
- Stalling problem, threw P0420 code., help?!
- Blowing coolant into overflow tank
- loud valve or lifter noise on d16y8
- bosch spark plug wires, and platinum = bad.
- Radiator fan(s) not working.
