98 civic ex won't start after replacing crankshaft sensor!!
I'm not the most mechanically savvy guy, but I'm poor, so when my car breaks I try to fix it myself...
The other day my wife was driving on the freeway and as she tells me, the car started smoking (she was late for work driving 90mph), smoke was coming through the vents, so she pulled over and the car wouldn't start after she turned off the engine. When we checked the error codes I got 2 codes for the crankshaft position sensor, so I replaced it along with the timing belt, driver's side axle and break pads... I still have to replace the passenger side axle & am having a really hard time popping it out from the transmission... So if anyone has any tips it would be greatly appreciated.
Herein lies my problem; after the replacement of the crankshaft sensor, the car won't start... I've got the battery hooked up to a charger, so I know it's getting juice... I'm pretty sure the starter is fine because it's bumping pretty good, the fuel system seems to be fine, and the only thing I can think of is that the timing is off... Maybe when I replaced the belt the tensioner messed up the timing? It's the first time I've ever done one... And I didn't see any timing marks on the old belt, or the new one.
The car is a manual transmission 98 Civic EX coupe with the 1.6L V-Tec stock engine. Someone please help!!!
Re: 98 civic ex won't start after replacing crankshaft sensor!!
timing marks are not on the belt, they are on the pulleys.....so that would be the first place to start.....turn the crank to its TDC position, then see if the cam is at TDC....
and why exactly are you replacing the drivers axle?
Don't waste coin on the axles if the engine won't run.
Figure that one out first.
Got compression?
Got compression?
I haven't had a chance to check yet, but when I manually turn the crankshaft I hear a hissing & feel resistance where the pistons would be firing... So that all seems pretty normal.
Yes, timing marks have nothing to do with the belt and everything to do with the engine.
Take it apart and get yourself a manual on how to set the timing marks the correct way.
Thats not relevant to the timing marks, just means you have some sort of compression.
SSMatey
Apr 13, 2015 06:09 PM
toastyghosty
37
Jun 10, 2002 01:07 AM
