flooding problems please help
ok so my g/f has a 2000 civic base model with the 1.6L and it floods its self so bad it just won't start anymore.
so far me and me mechanic friend have check the tps sensor ( he grounded it out or did what you had to do to see if it is bad or not) we replaced the plugs, we played with the timing
the wired thing about this is, in winter or even now ( its +10 out) if its pluged in it starts. there is alot of black **** coming out of the tail pipe ( un burnt fuel?)
dose anyone have any other suggestions?
thanks
thanks
Re: flooding problems please help
2000 Civic is fuel injected so it should not be able to flood itself at all. Are you sure it's flooding? You might be having issues with the Idle Air Control Valve. It might need cleaning or replacing. Black stuff might just be exhaust residue getting wet and coming out.
how did the plugs look when you replaced them? did you replace them with NGKs or DENSOs? how is your MPG?
there are a lot of things that can cause starting issues. what other problems are you running into? eg: hesitation during acceleration, poor fuel economy, etc...
more info please
well it has a ruff idle, It is gas because you can smell it ( smells like someone just spilled gas right beside you) once its started it seem to run fine except for the riff idle. the old plugs were.. well i never seen the plugs so bad before ( ngk iridium) and now we put in v power. As for the oil, the oil is checked regularly and is added when needed. Doesn't use a whole lot of oil tho but dose use some. We have no other problems besides this one her mpg seems good also whats CEL?
this morning we could not get it to start( was plugged in to). would turn over and over and over. as soon as we unplug the injectors ( turn it over to clear out any gas that was left in there) it wanted to start and would actually "catch" and run for a couple seconds but when we plugged the injectors back in same thing as before...just keep turning over and over and over. I tried boosting it and it fired up fine.
the battery dose seen a bit weak but i didn't think it would have made that big of a difference.
thanks
thanks
thanks
thanks
This was 14 years ago, start your own thread; list what problem you have and what you've tried to do to fix it
