What’s the purpose of the ICM?
Old Feb 11, 2024
Bugman1400's Avatar
Bugman1400 is an unknown quantity at this point
Got no spark, again. Replaced the ignition coil a few months ago and everything ran fine for a while, but now I seem to have a different no-spark issue. Tested the coil and got ~16k from spring to terminal and 0.6 between terminals. Decided to check the ICM on the bench with a pwm generator and o-scope and I get only a high output. There is no alternating signal to drive the coil. I assume the ICM provides an alternating ground source for the coil when an alternating input from the crankshaft sensor is seen.
I grabbed another dizzy from the junkyard, but its ICM also gave me only a high output. Do I have 2 bad ICMs or am I not testing this the correct way?
What function is the ICM serving here? Is it supposed to provide an alternating ground source with induction kickback protection from the coil?
joshepete
Feb 18, 2023 12:01 PM
old97civic
Sep 10, 2018 03:57 PM
kookoo
May 12, 2010 10:28 PM
JJJ
Jan 27, 2009 04:24 PM
motofabio
Dec 4, 2008 02:00 AM
