00 ex civix d16y8
Old Dec 8, 2015
919civic's Avatar
919civic is an unknown quantity at this point
00 ex civix d16y8
i have a stock d16y8 and it has a severe coolant loss i add coolant i can let it sit for ever and it will stay at normal temperature and wont lose coolant but when i drive it and hits around 3k rpm it will shoot coolant i changed the thermostat and radiator is 1 year old when under hard acceleration i see that water shoots from the radiator fill place i replaced cap also and no luck, i feel like theres a clog some where or something i pulled the radiator out put a hose in it and water flowed great so i dout its the radiator
Old Dec 8, 2015
Re: 00 ex civix d16y8
Head gasket............?
Old Dec 9, 2015
919civic's Avatar
why would it be the head gasket if it losses water at the radiator fill place
Old Dec 9, 2015
Your description is rather lacking in detail.
If it shoots out at the "fill place" then it should be easy to figure out why.
Does it come out where the radiator cap screws on?
Is the cap actually on correctly and fully seated?
Is the cap missing?
Does it come out of the nipple where the reservoir hose attaches?
Is the hose not attached and/or reservoir missing?
Has the engine been overheated since the radiator replacement?
Is the lower sealing surface burned out of the radiator neck from steam erosion, so the radiator cap will never seal pressure?
Why would the system suddenly gain a bunch of pressure at 3000 and shoot coolant out?
Old Dec 9, 2015
919civic's Avatar
Is the cap missing?
So I messed around with it today and yes the cap does not seal pressure I put rtv gasket maker on the cap and drove it and no over heating anymore and coolant stays in the radiator now
Old Dec 9, 2015
Sounds like it needs another radiator and cap.....?
Old Dec 10, 2015
919civic's Avatar
Yes it does ,I also want to buy a header on eBay the factory size is 1.75 and all the eBay headers are 1.6...the goal is for bigger headers right?
Old Dec 10, 2015
Originally Posted by 919civic
Yes it does ,
So WHY would it need another radiator and cap? What ruined this one?
My goals probably aren't the same as yours.
Moabrubi
Dec 7, 2015 06:38 PM
Natalie Nieto
Nov 28, 2015 01:34 PM
Abb0nz
Nov 26, 2015 10:53 PM
m3mo15
Oct 31, 2015 02:15 PM
raymondxcho
Sep 29, 2015 09:00 PM
