Radiator fan staying "On" too long after key is "off"
Old Oct 31, 2015
m3mo15's Avatar
m3mo15 is an unknown quantity at this point
Exclamation Radiator fan staying "On" too long after key is "off"
2000 honda civic. I replaced my battery and noticed the radiator fan instantly turned on, strange considering the car was cold so I did some searching and a little troubleshooting. The car isn't overheating, the fan turns off when the key is in the "on" position but turns on when the key is in the "off" position. with the key in the "off" position I pulled both "12" & "13" from this illustration http://www.hondaautomotiveparts.com/...TAT+%28SOHC%29 and the fan stayed on, I noticed the fan relay clicked intermittently so I swapped relays but it continued to click intermittently, that relay is getting an erroneous signal to turn on the fan but idk what controls that circuit. I drove to work, turned off the car and the fan stayed on for a good 30 min so I pulled the relay, a few hours later I put the relay back in and "on" came the fan, (keys in my pocket). I haven't had time to check anything else but please any would be great
Old Oct 31, 2015
Re: Radiator fan staying "On" too long after key is "off"
The temp switch on the thermostat housing and the PCM, both can control that relay but if you check out a wiring diagram the coil of that relay is only powered up when the key is on.
I'd look for the (radiator?) fan relay being stuck on instead. Contact points welded or stuck together. Get it to act up and whack it with a screwdriver handle or swap it with another identical relay.
califcamper
Jul 13, 2015 11:50 PM
Spanky4269
Jul 5, 2015 09:40 PM
trellex
Jun 30, 2015 07:13 PM
civiic143
Jun 29, 2015 06:15 PM
carlrock
Jun 3, 2015 09:36 PM
