PDA
View Full Version : Engine
Pages : [1] 2 3
  1. O2 sensor dummy fix
  2. Crank No Start '97 Civic
  3. Replaced Radiator/Thermostat, Coolant Temp acting up
  4. Losing cooland and oil
  5. Slow crank no start.
  6. Need Help: P0505 (Vacuum Leak)
  7. p0118 code after replacing head gasket; 2000 civic
  8. preferred lube for 1.6L camshaft installation
  9. Bleed system or Head Gasket Issue
  10. Why do my sparkplugs look like this?
  11. coolant in engine block 1.6L 2000 civic
  12. 2000 civic, 1.6L cyl head
  13. '96 Civic B swap No Crank No Start condition
  14. crank, but no start.
  15. no spark after removing distributor
  16. 95 Civic DX AT fluid leak
  17. Head Gasket question
  18. Throttle body diagram
  19. Help adjusting the timing
  20. 98 Honda civic starting issues
  21. Trying to find the right starter
  22. Engine cuts out at high rpm
  23. 98 Civic Ex misfire mania - any suggestions?
  24. High Idle at startup
  25. 1996 ek civic fan
  26. Going up to 1.5k rpm on idle after start, replaced IACV already
  27. D16Y8 Dies After Starting
  28. Misfire, Knock Sensor CEL. Car keeps running when pulling wire
  29. O2 Sensor Heater Resistance? NGK 24631, D16Y8
  30. Fuse 15 but no power to (O2 Sensors + Evap Relays). How to fix?
  31. Is there a difference in cables
  32. spark issues
  33. My vtec isnt hooked up
  34. D16 bolt threads
  35. 2000 Civic. Coolant loss from upper radiator hose housing?
  36. Best lifespan increasing mods.
  37. D16y8 - NEW ROCKER ASSEMBLY not sitting flush on Previous head?
  38. 99 Civic—stolen/recovered/started/WON’T start
  39. Thermostat DIY
  40. Boosted EM1 won’t got over 2000 RPM while in gear
  41. Front Muffler part replacement
  42. 1998 dx coupe transmission mount bracket missing
  43. Timing belt loose [solved]
  44. Fouling all plugs
  45. 98 civic Lx
  46. Valve Cover Bolt Size [solved]
  47. 2000 Honda Civic Idle Issue.
  48. Weird shake/shutter when accelerating hard
  49. Video: Loss of power accelerating, rough idle, no cel
  50. 99 civic ex wont turn over..
  51. Trouble finding matching parts
  52. Car Starts, then dies
  53. Oil in the coolant recovery tank/ Minor loss of coolant in the radiator.
  54. 98 ex new tank new pump no codes, won’t take gas
  55. Ac line broken!
  56. Harmonic balancer differences
  57. Catalytic Converter
  58. Engine Dying
  59. Any idea on the issue why car not starting?
  60. Anyone know where i can get a new fuel level sensor?
  61. valve cover bolt retainer snapped
  62. 96 Civic EX overheating
  63. steam coming from overflow reservoir with temperature staying normal.
  64. What’s the purpose of the ICM?
  65. Coolant loss
  66. B18c4 ej9 swap no spark
  67. Engine turns on but doesn’t stay on
  68. Help troubleshooting Fuel Relay issue
  69. Fuel pump no prime
  70. starts or cranks with no start (99 civic LX d16y7)
  71. Won't start
  72. No Crank No Start
  73. 98 civic lx tach flutters engine sputters
  74. Honda civic ek hatch radiator fan issue
  75. RPM redline at 4.5k rpm?
  76. Sputtering terribly after stalling in water
  77. Misfires Galore
  78. 99 Civic LX Fuel consumption problem
  79. 97 civic isseues starting after got done working on it
  80. intermittent starting issue
  81. Need some help
  82. I bought new engine for my civic 2000
  83. Removed Valve Cover and Now I Get Overheating and Sputtering
  84. 2000 hond civic lx/ex Engine quit running
  85. Intermittent knocking and misfire only @ temp! D16y8 [solved]
  86. 2000 Civic EX Fuel Tank Vent Valve [solved]
  87. Did I get hosed? D15B
  88. Distributor Cap
  89. High Idle On Hot Days on Slow Streets
  90. Throttle Body Question
  91. Timing belt tensioner
  92. Fuel Filter Replacement
  93. Problems after replacing oil pan
  94. Not firing??????? [solved]
  95. D16z6 swapped 98’ civic hx crank no start
  96. Delete EVAP pipe and canister
  97. Throttle cutting/capped
  98. 99 y8 swapped in 97 civic no spark just cranks
  99. Cel code 72, and 74 [solved?]
  100. High Pitched Engine Sound
  101. Radiator Fan
  102. 2000 civic ex p0505 help
  103. 96 Civic Vtec engine oil leak.
  104. Fuel pump only primes when it feels like it.
  105. Scratching/ scraping noise in 1996 [solved]
  106. No vtec? No oil pressure switch?
  107. '97 Civic EX Owners?
  108. 99 sedan civic not starting
  109. 1997 Honda Civic No Spark
  110. Stock 1999 Honda Civic LX WHAT DO I DO!?
  111. 1997 Civic Ex coupe Not starting
  112. 98 civic misfiring [solved]
  113. Surging Civic
  114. Not starting or running rough after warming up 2000 Honda Civic Coupe Ex
  115. Civic jerking at cruising speeds
  116. Overheated to death
  117. How screwed am I?
  118. Heating problem D16Y8
  119. Long cranking after drive while it rests
  120. Help to identify 3 sensor
  121. Crank no start, after dying while driving, intermittent no spark/fuel
  122. I have this dangling sensor in my 1998 honda civic. What is it for? [solved]
  123. Motor change
  124. Engine acting up [solved?]
  125. 1997 Honda civic, it has vTec but unsure of trim
  126. 99 civic, starts then immediately dies
  127. D16Y8. Check engine: P2258 Vtec oil control valve
  128. im stumped
  129. 99 Civic EX surging idle and stalls under loa
  130. 2000 Honda Civic d16y7 misfire [solved]
  131. VTech Solenoid oil leak
  132. Oil pan grommet [solved]
  133. Civic Lx engine replacement
  134. 1998 civic exhaust drone
  135. Camshaft key
  136. Mystery: civic intermittently dies.
  137. Cranks but will not fire
  138. 1999 civic lx problems after D16y8 swap
  139. Re: check engine light P1457 Evap. bypass solenoid valve
  140. D16Y8 Tick
  141. Drove through puddle - need advice
  142. HELP NEEDED! Timing cover seal 2000 Honda Civic LX
  143. VTEC Oil Leak that just won't Stop
  144. Excessive Oil Leak
  145. 2000 civic si d16y8 swap idling issues and coolant leaking
  146. Damaged head
  147. 98 lx P28 OBD1 conversion 2 and 3 wire IACV
  148. 1999 Civic DX hatch crank no start
  149. Stalled and won't start
  150. Heating and Idle
  151. How do you remove this from the block?
  152. engine problems
  153. 1998 Honda Civic Dx starts and dies immediately.
  154. 2000 Civic EX Rattles when accelerating up hill
  155. 1999 Honda Civic DX manual Crank no Spark
  156. Flickering Drive Light, Inconsistent RPMs
  157. Upper Inner Timing cover
  158. Idle / ac issues?
  159. Evap Issues 99 Honda Civic DX (FIX)
  160. 2000 civic engine removal
  161. Check engine light after accident
  162. Plug and Play Engine overhaul
  163. budget exhaust replacement
  164. 1998 Civic EX
  165. No crank/ transmission rebuild
  166. Engine runs hot/overheats unless fan switch is bypassed
  167. Help! Car shuts off randomly! [solved]
  168. car wont start after cleaning IAVC
  169. Loss of power
  170. 99 Civic Crank no Start
  171. 97 DX Hatchback Automatic
  172. Coolant temperature doesn't go as down as it should?
  173. Throttle body cleaning problem
  174. No Spark anymore after checking misfire
  175. 1300k on a rebuild, blowing smoke at high rpms
  176. Trying to figure compatibility out with the head on my 2000 Civic 1.6 l Y8
  177. 1999 Honda Civic Ex Coupe NOT STARTING after replacement battery, relays, and brand n
  178. Question about camshaft replacement.
  179. 2000 LX - No Start after timing belt, ignition coild
  180. Car cranks doesn’t start
  181. New head gasket, still losing coolant
  182. Confused with a part
  183. D16y7 distributor on d16y8 motor
  184. 1998 Honda Civic 1.6 single cam non vetch runs bad until redlined
  185. Crank no start after WP change [solved]
  186. 1998 Civic HX Performance Tune Up Kit
  187. 2000 honda civic ex sohc 1.6L
  188. 99 civic with D15B
  189. Rear main seal depth
  190. 98 Civic EX, seals going bad every two years.
  191. Honda 1998 b20 ballade
  192. Crank No Start [solved]
  193. 2000 honda civic ex
  194. Engine compatability?
  195. Re: Jack Accident
  196. White smoke when accelerating
  197. 1998 Civic Ej9 oil leak
  198. Guzzling Too Much Fuel
  199. 2000 Honda Civic
  200. 98 civic crank but no start
  201. 1998 civic D14A4 noise
  202. Rpms randomly drop and it won't accelerate
  203. part identification
  204. Oil Dipstick tube retainer (bracket/clip) part no???
  205. Brand new to Honda
  206. Car cut off while trying to park it. Wont restart.
  207. What's the 2nd cable?
  208. Flashing check engine light
  209. Blown Head Gasket
  210. Losing coolant
  211. Mystery part from cylinder head
  212. Losing coolant [solved - HG]
  213. Need help diagnosing Catalytic Converter P0420
  214. 1998 Civic EX Coupe Engine knocking/clunking while idle and when accelerating
  215. Coolant Leak Near Oil Filter (PS) 6th Gen 2000 Honda Civic EX Coupe
  216. Quality Head Gasket
  217. Cranks but doesn’t start
  218. Weird Bubbles from Radiator!
  219. d16y7 randomly stalls
  220. Stall once ect hits 150f
  221. Please help!! High RPM’s…
  222. RPM Went up about 1500, How to lower it down
  223. Car randomly misfires upon starting/Fuel trim is all out of whack.
  224. Need help
  225. 98 civic overheating, no heat, fan working
  226. Cranks but won't start. No check engine light.
  227. Blowing blue smoke when VTEC hits?
  228. fuel line replacement help
  229. 2000 ex p0420 [solved]
  230. Civic no start
  231. RPM jump/surge
  232. 99 civic dies while driving, cranks but won’t start
  233. Need Radio Help
  234. First Post, Trying to Avoid a Profanity-filled Rage Over Intermittent Starting Issue
  235. 2000 Civic engine randomly dies
  236. B16A2 won’t crank after headgasket replacement [solved]
  237. Loud noise in engine
  238. Need HELP ! 1999 Honda Civic D16y8 rough idle up and down
  239. 97 Civic Problems
  240. pressure in cooling system
  241. Misfires on a D16Y7
  242. Cost of TB replacement, 1997 Civic LX
  243. Help!!! Mystery misfire no start when hot not main relay
  244. 1998 I need help with timing (PLEASE HELP)
  245. Where's the power
  246. 1999 Civic occasionally wont start.[solved]
  247. P1259 Even After Bypass (V-TEC solenoid)
  248. 2000 civic d16y8 - oil pressure switch (location?)
  249. missing coolant
  250. 98 civic stalling out
