No crank/ transmission rebuild
My car isn't cranking over and I just put my manual transmission back in. Any common issues revolving around this?
Starter is working, its getting spark, and fuel gets to fuel rail. I haven't pulled the injectors yet
any help would be greatly appreciated
Re: No crank/ transmission rebuild
- when turning key, it clicks and nothing else
- battery is low in charge
- ground is not properly connected (battery connectors, engine ground, chassis ground, motor, etc)
- rodents chew wires
- Check relay
- solenoid is not engaging (stuck)
- get under the car and wack the motor to see if you can unstick it
- if does not work, remove starter and inspect/test.
- just put some 12V power in the poles and bench test
- have seen some cases of gears losing teeth
- when turning key, high pitch noise
- starter gear is not engaging with flywheel (yes, we saw cases)
- have someone check if engine is turning when you try to start
- remove starter and inspect/test it - see above
Firing order?
Are you sure you have spark?
You can check if the injectors are firing by holding a screwdriver to it while someone cranks it.
Compression?
Compression?
Dillano609
24
Oct 4, 2018 08:20 AM
Kristinb737
Apr 18, 2017 01:06 PM
MLRSFDC
Nov 10, 2013 01:08 PM
squirrelsurf69
Nov 16, 2012 09:14 PM
