Need Help: P0505 (Vacuum Leak)
Old Oct 2, 2025
Jayp's Avatar
Jayp is an unknown quantity at this point
Hey Everyone
I’ve been chasing a P0505 Idle Air Control code on my 2000 Civic EX (D16Y8). I ran a smoke test and the only place smoke comes out is along the entire top edge where the intake manifold meets the cylinder head (right where the gasket seals). It’s not coming from hoses, the throttle body gasket, or the IACV itself — it’s literally the gasket line on the top side
So far I’ve,
  • Replaced the intake manifold gasket (torqued bolts properly, surfaces cleaned).
  • Replaced the throttle body gasket as well just to rule it out.
  • Ran the smoke test again → still leaks right away along the same spot. CEL comes back within 5-10 minutes
Symptoms:
  • With the CEL cleared, car drives okay but feels kind of “rough” or like it’s not breathing right.
  • Once CEL sets, idle surges up and down.
  • Bogs and Hesitates to drive when CEL is on
Has anyone run into this before where a new gasket still doesn’t fix the leak?
What’s the best next step? Machine/resurface the intake manifold? Try OEM gasket instead of aftermarket?
What Should I do?
Appreciate any advice — I just want to get rid of this leak and the P0505 for good.
Old Oct 2, 2025
Colin42's Avatar
Re: Need Help: P0505 (Vacuum Leak)
Check the intake manifold and head surfaces for flatness, try with an oem gasket
diverdwn
Jul 6, 2014 03:33 PM
MarkoPollo
Oct 11, 2011 11:18 PM
STREETFIGHTER50
Jun 6, 2011 10:46 PM
Turbochainsaw
Buy, Sell, & Trade - Archive
Feb 25, 2009 08:32 AM
0321
Jun 28, 2007 01:06 PM
