Slow crank no start.
Old Oct 17, 2025
bluejay412's Avatar
bluejay412 is an unknown quantity at this point
Hello I have a 1999 Honda civic hatch, the person I had bought it from geto wired in the radio so I redid the radio wiring and now the battery light is on and the car cranks super slow, like the battery is almost dead, hooked up the jump pack nothing, new battery nothing. I changed around some relays and nothing. Checked all fuses and grounds nothing. Is there some sort of safety or something I’m missing? Any input or thoughts will help greatly
Old Oct 17, 2025
bluejay412's Avatar
Re: Slow crank no start.
It’s also a Manuel and I tried to bump it with no luck just acts like it’s cranking slow
Old Oct 17, 2025
Colin42's Avatar
If it worked before you touched the wiring you need to check your work. Battery light with engine off is normal, with the engine running it usually means that the alternator isn't charging. Only use an oem alternator
Old Oct 17, 2025
bluejay412's Avatar
I’ve checked over the wiring with a fine tooth comb and nothing is different from when I started, except I actually added connectors other than them just being twisted together.
Old Oct 17, 2025
Colin42's Avatar
So check if the alternator is charging
Old Oct 17, 2025
bluejay412's Avatar
it won’t start so I wouldn’t be able to do that, it just clicked I had a ticking and that all the bolts that hold the rockers in where loose, they seated down pretty far and I’m sure the valves are open so it basically has no compression gonna relash them like I should have after I tighten those bolts
Daflowne
Mar 19, 2015 09:16 PM
Jacoburn1304
Aug 19, 2013 06:41 PM
catchfast11
Jun 22, 2012 02:51 PM
BiggSean
Jul 14, 2011 08:25 PM
goliath
Jul 20, 2010 06:33 PM
