'96 Del Sol no crank/start
Old Mar 19, 2015
Daflowne's Avatar
Daflowne is an unknown quantity at this point
Alrighty, here's what I know so far:
Went into a store, came out, no crank.
Attempted push start, and cranked.
Suspected bad Starter, attempted to jump the starter, starter is fine
Pulled out the clutch switch, hooked up a volt meter, get a distinctive on/off connectivity when I press the button.
When I put the key into the ignition and turn to II, dash lights and radio come on, and I hear the fuel pump as well. If I turn to Start, nothing happens. the only click I hear is my automatic locks attempting to lock.
Any advice to help me get back on the road would be greatly appreciated.
Thank you.
Old Mar 19, 2015
oneheadlight's Avatar
oneheadlight is an unknown quantity at this point
Re: '96 Del Sol no crank/start
Thank you.
have you checked the battery voltage? It could also be a bad cell in the battery, have to get a load test on that battery. The battery could be putting out enough juice to get the radio and lights on but not enough to start the car. If you do get a battery, I just got mine from advance auto, using code I think it was TRT41, saved me $40 Just to help you out..
Old Mar 19, 2015
Daflowne's Avatar
I haven't, but I have attempted to jump start it with no luck.
Old Mar 19, 2015
ahh yeah sounds like a bad cell in the battery. Jumping a bad battery, nothing will happen. Sounds like it's time for a trip to get a new battery but definitely load test your existing one to see how far gone it really is.
Old Mar 19, 2015
Daflowne's Avatar
alrighty, didn't know that. thanks. I'll check that out and report back.
Old Mar 19, 2015
Daflowne's Avatar
Think I found the problem...
Old Mar 19, 2015
ok.. what IS that?? Looks like candy corn.. lol
Old Mar 19, 2015
Daflowne's Avatar
It's part of the little rubber/plastic stopper that was inserted into the clutch pedal that makes contact with the clutch switch.
PierrePierre
Aug 12, 2015 02:42 PM
civicdude
Jul 22, 2011 10:37 PM
Jodster
Mar 30, 2003 12:41 AM
Jon
Mar 27, 2002 08:25 PM
