Timing belt tensioner
This tension doesn’t seem right. I replaced belt, tensioner, and spring. Followed installation instructions. Set TDC. Loosen tensioner 180*. Rotate crank CCW 3 teeth. Tighten tensioner to 33 ft lb. Once I do that I get
good tension on the front side and a little slack on back side which should be good. Once I rotate CCW I get slack on the front side “cam to crank” and then it tightens up again.
here’s a video of how it runs. Just doesn’t look right to me.
https://youtu.be/QanRvbZFntc
Re: Timing belt tensioner
the last month. I found an oil leak on front main seal and the tensioner was bent along with the spring. Started digging into the belt.
so I got everything on and it tightens up but then it gets loose again. I’m working on taking lower timing cover off again right now. Might take like 20-30 minutes.
Is there a such thing as “too tight” I threaded a 14AWG wire through the hole of the tensioner and pulled it tight while rotating engine CCW. Now it’s tight tight. Should there be a little slack on the water pump side or it will be ok? I’ve rotated engine multiple times and it no longer gets loose.
taking a break for now. It’s hot outside.
I was able to loosen and get some slack but it was making some noise like it seemed too tight. Loosened again and now it looks and sounds much better. Gonna work on putting it all back together tomorrow morning and also do another valve adjustment while I have the valve cover off to put back the upper timing cover.
Here’s another video. I think this looks correct now.
https://youtube.com/shorts/nlW5NFldGuo?feature=share
5.0Thunder
Sep 20, 2017 07:27 AM
honda.lioness
Sep 15, 2017 10:07 AM
dbailey
Jul 30, 2016 02:57 PM
WaryDriver
Aug 16, 2015 11:22 AM
BUFF
Dec 7, 2010 07:14 PM
