98 civic misfiring [solved]
Old Jun 3, 2023
Maqcro's Avatar
Maqcro is an unknown quantity at this point
Last week I did a valve adjustment. It’s been starting and driving great all week. Today my civic started sputtering on startup. After idling for about a minute it runs fine. I set intake to .20mm and exhaust to .25mm but I didn’t realize there was timing marks on the back of the cam to find TDC of each cylinder. I followed firing order 1-3-4-2 as I adjusted and rotated engine counter clockwise.
I’m now getting two DTC
P0301 - cyl 1 misfire
P1399 - random misfire detected
I replaced cap/rotor and plugs/wires and reset codes. Sputtering on startup still happens, Codes come back.
Is it possible I didn’t do adjustment correct last week and why now all of a sudden is it acting up?
Old Jun 5, 2023
BrotatoChip's Avatar
Super Moderator
re: 98 civic misfiring [solved]
It would definitely be worth double checking.
Old Jun 5, 2023
Maqcro's Avatar
just double checked it. I had 1 or 2 on the exhaust side that were slightly out of spec. Adjusted and put it all back together.
Idk if I just found the issue as I’m typing this but the idler pulley going to the ac compressor fell off. If I crank with ac turned off it starts no problem.
I must have forgotten to tighten down the pulley when I replaced the engine 😆
Old Jun 5, 2023
Colin42's Avatar
That happens sometimes
Old Jun 6, 2023
Maqcro's Avatar
ok so here’s the update. Pulley is back on and tightened this time. I reset the engine light but it came back right away after starting up for a 2nd time. I also have white smoke coming out of the tailpipe.
Old Jun 6, 2023
Colin42's Avatar
White smoke isnt good. Usually means headgasket problems
Old Jun 6, 2023
Maqcro's Avatar
I have a compression tester. Should I go for both compression test and leak down test? Each Cylinder needs to be in TDC for leak down correct?
Old Jun 6, 2023
this is the surest way to test for headgasket breaches, simple and effective.
Originally Posted by sdaidoji
no need to buy kits to test. Often they don't det3ect small breaches.
this test is surely to catch them, cheap and simple. It's in the link posted before
https://www.youtube.com/watch?v=bDHkaU-EndY
Old Jun 6, 2023
Maqcro's Avatar
thank you for the post. I’ll try to get this done tomorrow.
Old Jun 6, 2023
Maqcro's Avatar
compression test results
Dry
  • Cyl 1 - 200
  • Cyl 2 - 170
  • Cyl 3 - 170
  • Cyl 4 - 190
Wet
  • Cyl 1 - 210
  • Cyl 2 - 210
  • Cyl 3 - 205
  • Cyl 4 - 205
leak down test is next. Just gotta find my compressor
Old Jun 6, 2023
Colin42's Avatar
Comp looks good
Old Jun 6, 2023
Maqcro's Avatar
Comp looks good
Just did cylinder 2. Blowing air into cylinder 1 and air out top of radiator. Trying to get a video for your viewing pleasure.
Old Jun 6, 2023
Colin42's Avatar
Booo
isn't this your new used engine?
Old Jun 6, 2023
Maqcro's Avatar
Booo
yep. Fresh from the machine shop
Old Jun 6, 2023
Colin42's Avatar
Call them and give them hell. Especially with what happened with the valves
Old Jun 6, 2023
Maqcro's Avatar
gonna drive it up to them and drop it off
Old Jun 6, 2023
Maqcro's Avatar
https://youtube.com/shorts/MIzIurDnXO8?feature=share
Old Jun 6, 2023
woah, that is... huge leak...
Old Jun 6, 2023
Maqcro's Avatar
I’m sure you can understand the frustration. The engine was rebuilt top to bottom and was supposed to be ready to drop in without issues.
they failed to do the valve adjustment
they lost one on my nuts that holds down the valve screw
lost two oil pump bolts causing huge oil leak
head gasket has failed after 300 miles in short trips no heavy acceleration or high rpm
Old Jun 7, 2023
Super Moderator
A literal fountain of coolant out the top of the radiator.
Old Jun 12, 2023
Maqcro's Avatar
I brought the civic to the shop that rebuilt the motor and they didn’t want to believe me. Glad I had proof of compression test and leak down test before showing up. After the owner saw the video of coolant fountain he still had to take a look. He couldn’t believe that was the same rebuilt motor that came out of HIS shop. Also showed him the missed oil pump bolts and valve adjustment nut. He hinted that it was one of his newer mechanics in the shop and that they will be having a serious talk about what happened here.
he promised the engine will be fixed free of charge or they will find me another engine, rebuilt that will work.
Old Jun 13, 2023
Colin42's Avatar
Glad to hear that they're willing to make things right
Old Jun 13, 2023
Maqcro's Avatar
Re: 98 civic misfiring [solved]
They came back after looking at it and said that most likely the block is warped. Recommend resurfacing block and head and then using a different head gasket that is thicker instead of the MLS gasket. Thoughts?
Old Jun 14, 2023
Colin42's Avatar
If they're covering the cost let them go nuts
Old Jun 14, 2023
Maqcro's Avatar
I guess my question was leaning more towards, would this be the appropriate or acceptable repair?
just finished pulling the engine. Much quicker than pulling the transmission too 😆. Only took 2.5 hours this time.
Edit: oh I forgot to mention that for the warranty they want me to pull the engine and drop it off. Idk if that seems fair but they said it’s because they are too busy to remove the engine themselves?
Old Jun 14, 2023
Colin42's Avatar
As long as they're giving you warranty thats fine
Old Jun 14, 2023
it's uncommon to see the block needing milling on these cars, really...
Old Jun 14, 2023
Maqcro's Avatar
The engine was just dropped off. They said they will check for any warping and resurface if needed. Thank you for that into btw. What are your thoughts on using an oversized head gasket? Also I requested that I see the head and block myself before they put it all back
together. I would like to take a machinist ruler and feeler gauge myself and see how flat the surface really is or is not.
Old Jun 14, 2023
Colin42's Avatar
Pretty sure it was warped on my 2000, did the head + gasket, was still overheating and pushing exhaust out the rad. So i changed the engine
Old Jun 14, 2023
Maqcro's Avatar
Sorry if I have been asking a lot of questions. I am a bit frustrated with this engine and I’m just trying to get the best possible resolution here. I appreciate all the input and all the help with everything so far.
