Won't start
Old Jan 16, 2024
Dargui's Avatar
Dargui is an unknown quantity at this point
Won't start
Hello everyone, I can't find my problem.
I'm trying to bring back to life an EJ9 (D14A4) who doesn't have run for almost 10 years.
I cleaned it up inside out change the old fuel, fuel filter, put a new pomp in it (the reservoir is rusted ( i bought a new one but didn't put it on it yet)), batterie and it stared for a time !
I do some deeper cleaning move it a bit, do very small run (less then a km with it). the idle was very bad ~500t/min, i don't know why and then won't start anymore.
I think in English it's called crank but won't start, to list the symptom:
- the started is running
- i got spark - fuel is coming to the fuel ramp and i can ear the pump when i put ignition
- no check engine light
- not even one cyl is having the desire to start (so i suspect it's not an injector whose failing)
- all fuse seems ok
I try some research on internet with the "crank no start" and mostly they say it's ignition coil, so i put an second hand one, still don't do the trick..
so i'm a bit lost, if someone have an idea or can orient myself toward the problem would be great!
Thank you
Succubus062388
Dec 20, 2019 06:37 AM
the.tetrix
May 10, 2016 07:00 PM
Sethster99
Apr 6, 2013 12:51 PM
jt1civic
Apr 20, 2012 11:20 AM
Michalo187
Oct 10, 2005 11:52 AM
