Engine wont start
Old Dec 18, 2019
Succubus062388's Avatar
Succubus062388 is an unknown quantity at this point
Question Engine wont start
Okay so problem and I'm at my white end figuring it out. 93 civic ex 1.6l wont start replaced, distributor assembly, fuel injectors,spark plugs and wires, new starter and new ignition control module. No idea why it still wont start. Turn key and go to start it and it's just that like it wants to start but doesn't noise..... checked ignition relay and ecu fuse also under hood
Old Dec 18, 2019
Colin42's Avatar
Re: Engine wont start
So crank no start?
Or no crank no start?
Got fuel? Got spark? Compression? Flooded?
Old Dec 18, 2019
No spark, has crank, is not flooded has fuel
Old Dec 18, 2019
Colin42's Avatar
Did you put in an aftermarket distributor?
put in an OEM one from the junkyard
Old Dec 18, 2019
It is a new OEM distributor
Old Dec 18, 2019
Colin42's Avatar
You sure it's an OEM one? How much was it? Up here a new oem dizzy would be worth as much as the car
Old Dec 19, 2019
Yes it's a spectra part and still doesn't help to know why no spark. Tested distributor components and they tested fine.
Old Dec 19, 2019
Colin42's Avatar
Spectra isn't OEM....
Old Dec 20, 2019
So can you please tell me what the difference is between going to a junkyard and pulling a crappy one off a car and buying a brand new one is.......the distributor tests perfect.....so not seeing how that could be an issue
Old Dec 20, 2019
Colin42's Avatar
Honda's don't like aftermarket electronics, especially distributors, alternators, and sensors. Lots of people come on here with problems that are fixed by removing the aftermarket part and putting an OEM one on. Find a car that looks like it was wrecked, then you know that the engine was running before the car went to the junkyard
jasonle88
May 3, 2016 06:22 AM
Gunsbee
Dec 3, 2015 09:34 AM
Fishlamp
May 19, 2013 06:23 PM
Sethster99
Apr 6, 2013 12:51 PM
99 Civic Ex
Nov 26, 2012 05:41 PM
