2000 honda civic ex
Old Mar 22, 2022
Shaunhavens53's Avatar
Shaunhavens53 is an unknown quantity at this point
2000 honda civic ex
I have a problem with power loss and jerking in the transmission at operating temp which is about at half way! And i done changed the alternator, distributor, wires, plugs, fuel injectors, idle air control sensor, map, tps, torqued the valves to proper spec because they was lose and out of wack i got a code for it and did it asap, new fuel pump, transmission shift solenoid i dont know what else to do! This is crazy i thought i done everything but obviously not.. I need major help plz
Old Mar 22, 2022
Colin42's Avatar
Re: 2000 honda civic ex
What codes do you have? Did you buy OEM or aftermarket parts?
Old Mar 22, 2022
Throwing a heater sensor circuit code and knock sensor the only two that stays on all the time and no nothing aftermarket
Old Mar 22, 2022
Colin42's Avatar
The parts you changed are all OEM Honda? Not whatever garbage Advance/Oriellys sells?
actual code numbers would be better, but I'll guess that the heater circuit code is for the primary o2 sensor, might cause some driveability but shouldn't be major. Fluid changed? Level, colour, condition? Correct fluid? Drain and fill only no flushing machine?
Old Mar 23, 2022
I did change the trans fluid and i did buy all my parts from multiple places.. I probably shouldnt have gotten the distributor off Amazon but if it wasnt gud then im sure it wouldnt run.
Old Mar 23, 2022
Colin42's Avatar
Might have gotten counterfeit parts, unfortunately you fired the parts cannon at it so that makes diagnosing more difficult
And it will "run" with an aftermarket dizzy, just not well
Old Mar 23, 2022
So where do i got to go online to get the real deal? Im new to the hondas wanted one forever ago an finally got one im planning to do a rebuild here soon and i want to be able to get all my parts from one place
Old Mar 24, 2022
Colin42's Avatar
This thread lists dealers that sell online
https://www.civicforums.com/forums/1...re-buying.html
Some parts you can get from rockauto because they sell the oe brand (Denso, NGK, etc).
It's mostly sensors and electrical components you have buy OEM. As well as timing belt components and head gaskets.
Suspension/brakes, and other things you can get away with aftermarket
hohonok
May 28, 2014 05:54 PM
suzyy13
Feb 22, 2014 01:32 PM
margorita03
Oct 3, 2012 08:27 AM
incrhulk
Mar 9, 2012 01:32 PM
