Loss of power
Old Aug 7, 2022
Maqcro's Avatar
Maqcro is an unknown quantity at this point
Loss of power
98 civic lx
I power washed under the hood a few weeks ago and after washing i was getting crazy misfires.
I waited for everything to dry off more and the misfires went away but since the day I washed the engine i have had horrible acceleration and no power. Struggle
to go up hills.
since then I have changed spark plugs and wires with no change.
Old Aug 7, 2022
Re: Loss of power
open distributor cap and see if anything in there.
check if there are cracks on the cap
water pressure can also dislocate sensors if not fully pressed in.
Water left over on connectors
water left over in wire repairs
did you keep water jet way from the air entrance?
Old Aug 7, 2022
Maqcro's Avatar
Re: Loss of power
I replaced distributor assembly about 3 months ago but I can pull cap off and check anyways.
as for water I mainly tried to stay away from air filter but of course some water probably got in placed it shouldn’t be.
Old Aug 7, 2022
Maqcro's Avatar
Re: Loss of power
The only code that I had was P1705 but was on prior to washing and has been fixed since. So no engine codes currently.
wouldn’t a dislodged connector throw a code?
Old Aug 12, 2022
Colin42's Avatar
Re: Loss of power
Maybe maybe not. WD40 is a water displacement solvent. You can try that on some of the connectors. Check everything is good with the distributor.
Old Aug 12, 2022
Maqcro's Avatar
Re: Loss of power
i replaced cap and rotor. They looked horrible btw. Seemed to improve a little but still not great. Took another look around and found a vacuum hose disconnected. I was also 3 quarts low on oil.
haven’t driven it up a hill yet but seems a lot better after the vacuum line and adding oil. I was only getting 120 miles for a tank of gas. 😭
Old Aug 12, 2022
Colin42's Avatar
Re: Loss of power
3qts low?
thats like 90% of the oil in the engine, you're lucky you didn't blow the engine. It might still fail.
Old Aug 12, 2022
Maqcro's Avatar
Re: Loss of power
3qts low?
it’s driving fine for now. I have an oil leak at the oil pan that I keep meaning to change but don’t have the time. I ordered parts for it a few months back.
Old Aug 14, 2022
Maqcro's Avatar
Re: Loss of power
3qts low?
so looks like I have somewhat of an issue. I’m just gonna assume oil in the coolant reservoir is a big problem.
head gasket? Might explain loss of power?
Old Aug 14, 2022
FRSam's Avatar
Click Here
Re: Loss of power
Oil? That would be strange. Typically it would just push more coolant out, though I suppose if it completely pushed all the coolant out, then maybe it would push oil?
Old Aug 14, 2022
Maqcro's Avatar
Re: Loss of power
Looks like oil to me. Where else could the oil come from?
also I did run out of coolant and engine overheated. Fixed cooling hose, filled, and bled air.
Old Aug 14, 2022
Colin42's Avatar
Re: Loss of power
Probably a blown headgasket, you should just swap the motor at this point
Old Aug 15, 2022
FRSam's Avatar
Click Here
Re: Loss of power
My bad, mobile won't immediately tell me what subject this is under. My mind immediately went 7th gen. Definitely a failed head gasket.
Old Aug 15, 2022
Maqcro's Avatar
Re: Loss of power
what are the chances that it’s just the gasket and not warped or cracked head? Obviously the gasket would be alot cheaper than an engine.
Old Aug 15, 2022
FRSam's Avatar
Click Here
Re: Loss of power
Given the engine overheated, virtually no chance.
Old Aug 15, 2022
Maqcro's Avatar
Re: Loss of power
ok. My engine has no vtec. Can it be replaced with an engine that has vtec?
Old Aug 15, 2022
FRSam's Avatar
Click Here
Re: Loss of power
Yes, but assuming you don’t change the ECU or wiring harness, it’ll simply act like a non-VTEC.
Old Sep 6, 2022
Maqcro's Avatar
Re: Loss of power
So what was assumed to be engine oil mixing in my coolant tank is actually transmission fluid.
At what point would coolant and transmission meet? Some kind of trans cooler or radiator?
Old Sep 6, 2022
Colin42's Avatar
Re: Loss of power
Trans cooler at the bottom of the rad. You'll see it if you look in the engine bay
Old Sep 6, 2022
Maqcro's Avatar
Re: Loss of power
ok I’ll take a look today
Old Sep 7, 2022
Maqcro's Avatar
Re: Loss of power
looked yesterday but couldn’t find a separate cooler. Traced trans lines back to bottom of radiator but it’s all one assembly. I’m assuming this is what we are looking for.
Old Sep 8, 2022
Colin42's Avatar
Re: Loss of power
Yeah it's integral to the rad like every other car.
Denso is the oe supplier
cfd457
May 26, 2011 11:56 PM
ultimatetuner10
Oct 6, 2006 11:14 AM
booba5185
18
May 14, 2006 06:17 PM
trev0006
Nov 4, 2004 01:28 AM
skarteez
Aug 3, 2004 07:07 PM
