Plug and Play Engine overhaul
Old Sep 12, 2022
Wicked-Witch's Avatar
Yea, i drive a stick...
Wicked-Witch is an unknown quantity at this point
Hiya everyone! I want to get my little car running great. It's had 176,000 really hard miles. I just got it and it just gobbles oil.
I was curious about something that I hadn't found an answer for that I searched.
I want to do an overhaul on the motor, but I don't have micrometers or any fancy engine rebuild stuff to do it myself.
So, I was curious if I can unbolt the cylinder head and send it to a shop and have them do all new valves seated and get that resurfaced etc etc. And do the same for the bottom block, and when I get both of those things back, can I buy new pistons, rings, seals, etc etc. And basically plug everything back together? (Following torque and order etc). Or does it all have to be done by a shop?
It's a very mechanical question that I hadn't even found an answer to on YT even. D16 engine (nothing too fancy).
Thank you in advance!
Old Sep 12, 2022
Colin42's Avatar
Re: Plug and Play Engine overhaul
Theoretically yes, should all be checked properly though
Old Sep 12, 2022
Bugman1400's Avatar
Bugman1400 is an unknown quantity at this point
How much $$$ are you expecting to spend and how long are you expecting to drive a Gen 6 before everything else fails on it?
If you’ve never overhauled an engine, then its best leave it up to the pros. You’ll get what you pay for. Try and do it the cheap way or take shortcuts and you could waste both time and money and be left stranded. Find a reputable Import shop with good reviews.
Old Sep 13, 2022
The concept of my question is to save money and diy...can it be done. What is your worry about it?
Old Sep 13, 2022
why do you think it must be done in a shop?
example: do you know someone that have the tools or have done similar work?
Old Sep 13, 2022
Bugman1400's Avatar
My worry is that your lack of experience with rebuilding an engine will neither save you money nor time. If you have an experienced friend that has all the specialty tools and can really help, then I say go for it. Or, you could take this as a challenge and prove me wrong. But, if you REALLY want experienced advice, look for a reputable shop.
Old Sep 14, 2022
Well that doesn't really get into the fine toothed of what experience has to offer besides being able to chunk it all back together faster. If anyone can read and follow directions...why not. I'm not being difficult, I'm just looking for a more technical response as to why someone would say NO.
Old Sep 14, 2022
Colin42's Avatar
Do you know how to use micrometers?
Old Sep 14, 2022
Pretty sure they can't be too difficult to figure out...and what would those be needed for?
Old Sep 14, 2022
Colin42's Avatar
For precision measuring.....
Old Sep 14, 2022
Wildcat445
Nov 6, 2017 11:46 PM
dannyboy21
Apr 20, 2017 11:45 PM
pmjr0987
92
Apr 21, 2013 10:02 PM
recap
Jan 27, 2012 09:05 PM
Nacho4750
Jun 29, 2008 09:07 PM
