98 civic won't run
Old May 13, 2011
cfd457's Avatar
cfd457 is an unknown quantity at this point
98 civic won't run
My 98 civic won't start. It was running fine and quit all of a sudden will not start back up I checked if it is getting a spark, no spark .There is power to the coil and to the icm the cap and rotor look a little worn but still should work the motor cranks good is there any easy way to check the coil and icm. Instead of the buy a new one and see if that fixes the problem.
Old May 23, 2011
mtgit's Avatar
mtgit is an unknown quantity at this point
Re: 98 civic won't run
I have same problem, did you get it sorted? if so, please let me know, thanks
Old May 26, 2011
teahou's Avatar
teahou is an unknown quantity at this point
Take the distributor cap off and crank the engine. If the rotor is not turning, most likely the timing belt broke.
If it is turning, check the inside of the distributor cap for arc lines. These look like faint pencil lines in the plastic, and would indiciate the spark is arcing around in the cap instead of going to the plugs. Is there spark at the cap from the coil?
vtec92
May 4, 2017 03:20 AM
usajags84
15
Aug 19, 2015 03:12 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
