Help troubleshooting Fuel Relay issue
Old Feb 5, 2024
dmk's Avatar
dmk
dmk is an unknown quantity at this point
Hi. I'm working on a 2000 Civic that cranks but does not start. I've downloaded the service manual and I'm following the troubleshooting steps for the Fuel Supply system. The first steps related to checking circuit to the pump and for testing the relay all tested out ok. When I got to the section for testing for an open or short in the STS line, I got a reading of 9-VDC instead of 12-VDC. So it looks like I've a voltage drop in that circuit. What I can't seem to locate is a diagram showing where that line connects. The manual says to check the line from the PGM-FI to the Starter Signal fuse (31). That line looks ok so the problem is on the other side of the fuse - and thats what I can't fine info on. Any help?
Old Feb 6, 2024
BrotatoChip's Avatar
Super Moderator
Re: Help troubleshooting Fuel Relay issue
Did you check fuel pressure at the engine to determine something was wrong with the fuel system?
Old Feb 6, 2024
dmk's Avatar
dmk
Fuel pressure is fine. Only getting 10vdc on pin 2of the PGM-FI. I'VE traced it back through the fuse box and it's 10vdc all the way back to the ignition switch. That's not normal, is it? Voltage before the switch is 12.8vdc, so close to a 3vdc drop in the switch?
redgar-atx
19
Dec 6, 2022 03:53 AM
chriselfpen
Electrical
Jun 8, 2022 10:40 AM
RIPSAW
Apr 24, 2016 12:32 AM
flamehazeist
17
Aug 3, 2013 10:27 AM
parsonbg
Jul 3, 2011 10:15 PM
