pressure in cooling system
Old Jun 22, 2021
_gregrice's Avatar
_gregrice is an unknown quantity at this point
hey ya'll. ive got a problem with my cooling system in my 99 ek. got the stock d16y8 and its building pressure and pushing coolant into my resevoir and got no heat but it doesnt overheat unless idling and the fans dont come on at idle. i bled the system with new coolant and flushed my resevoir and put Rislone stop leak for cooling systems in and its been fine for a few days(fans coming on) until last night. no black film in the resevoir and no milky oil. anyone know whats going on? i have the headgasket at my shop cause i know its gonna have to be done at some point so if thats the issue then ill replace it asap. also let it idle for almost 10-15 mins and it didnt overheat but i checked the rad today and no coolant and my resevoir was almost full to the top.
Old Jun 22, 2021
mac25's Avatar
Dr Krieger of Modification
Re: pressure in cooling system
Ya the hondas usually fail with exhaust gas venting into the coolant causing over pressurization. Rear to see oil in coolant.
-probably due for the head gasket
-Make sure the thermostat and fans and fan switch/temperature sensor are good too, because you dont want the new gasket to fail if it was caused by overheating.
Old Jun 22, 2021
same problem as a 7th gen.
test method in the first post movies
https://www.civicforums.com/forums/3...reference.html
remove that stop leak immediately from the engine!
Db2004
Nov 20, 2020 03:59 PM
SJRhino
Nov 21, 2016 08:07 PM
drea782003
May 16, 2012 04:12 PM
ratsbreath
Mar 19, 2009 08:34 AM
myflybox
Nov 22, 2008 06:15 PM
