Misfires Galore
Old Dec 4, 2023
ArmyofMany's Avatar
ArmyofMany is an unknown quantity at this point
Misfires Galore
I drive a stock 99 DX civic. Its my daily. My CEL started flashing on my dash about a week ago. Ran OBD2, got codes p0300, p0301, p0303 and p0304.
Listed below is what ive done to try and fix the misfires. Car still turns over fine, doesnt stall either. Only has a hard time accelerating from a stop and idles rough. When pulled old plugs there was a lot of carbon build up for them being only 2 yrs old.
New plugs gapped at following
​​​​​.041 .040 .041 .041
New spark plug wires
New cap and rotor
No milky oil
No excessive white smoke from exhaust
Normal clear anti freeze
Fuel filter replaced this yr march
Air filter replaced last yr October
Compression test. Results listed (No lost of compression) C1=170 C2=165 C3=180 C4=180
Cat and exhaust mainfold replaced this yr march dur to a crack in manifold leading to a vacuum behind the heat sheild.
"New distributor" from junk yard
Sprayed wires with water at night. (Saw no arc between wires).
Sprayed carb cleaner on cold engine near intake manifold, fuel lines and air intake. (No change in rpm).
Checked all fuel injectors with multimeter and screwdriver to ear. (All right ohms and heard rhythmic ticking in all)
Next was going to unplug sensors controling air intake readings. Any other suggestion? Ive tried so much and nothing is coming up.
Old Dec 4, 2023
Colin42's Avatar
Re: Misfires Galore
Clean the iac, checked ignition timing? what brand are the new plugs?
Old Dec 6, 2023
ArmyofMany's Avatar
Re: Misfires Galore
Plugs are NGK and so the wires. Was going to check engine timing today if it does rain. Whats the IAC?
Old Dec 6, 2023
Colin42's Avatar
Re: Misfires Galore
Idle air control, on the throttle body
sovyna
Mar 29, 2019 05:11 PM
streffpilot
Mar 7, 2015 06:28 PM
zaltounian
Oct 31, 2012 06:38 AM
JapSir
Apr 14, 2011 12:42 PM
boffadees2
Mar 4, 2011 03:40 PM
