Long cranking after drive while it rests
Old May 2, 2023
Doktor2609's Avatar
Doktor2609 is an unknown quantity at this point
I've got a problem with my 98 civic, d14z2 with LPG. It takes 5 or 6 seconds of cranking to start after I drive it and leave it resting half an hour or more. But if I leave it resting loger, like for 24 hours it starts right up, no problem. If I turn it off after it cranks and starts, the second start is normal and starts right up. So only after sitting between 1 and 24 hours it cranks long. I changed the fuel filter, spark plugs and the coil, distributor and else was changed 2 years ago. Tries to turn the key off and on 3 or 4 times to make the fuel pump pump mores gas but it's the same problem. I've god a cel for rich/lean mixture and for secondary o2 sensor. Does anyone know how to fix this issue?
Old May 3, 2023
Colin42's Avatar
Re: Long cranking after drive while it rests
No clue about lpg cars unfortunately. My guess would have been fuel pump. Maybe a temp sensor that isn't reading correctly?
RotorBeav15
Jul 10, 2017 11:51 AM
Jameron_Caster
Mar 19, 2015 08:14 AM
Sethster99
Apr 6, 2013 12:51 PM
forevermemorabl
Jan 24, 2013 10:48 PM
gearbox
Engine start problems
Sep 27, 2006 03:45 AM
