2000 Honda Civic d16y7 misfire [solved]
Old Mar 6, 2023
oluvera6447's Avatar
oluvera6447 is an unknown quantity at this point
I have a 2000 Honda Civic 1.6 with the automatic. Bought it with a misfire. Set code p1399 p0301 p0302 p0303 p0304 and p300. I have tried everything on this car to get rid of it fuel filter fuel injectors spark plug wires spark plugs multiple distributors and crank sensor. Checked compression it's 195 on all four holes. Checked timing and reset timing multiple times same thing. Still has an uneven Miss with AC on at idle and under load engine light flashing anyone have any ideas?
Old Mar 6, 2023
re: 2000 Honda Civic d16y7 misfire [solved]
how does the plugs looks like?
cracks in the distributor cap?
any signs of coolant in the cylinders?
Old Mar 6, 2023
Plugs look good. They are ngk plugs. New distributor no cracks no defects I can see. Same symptoms with 4 distributors. No coolant in cylinders and no less of coolant anywhere. Passed a coolant pressure test
Old Mar 6, 2023
Colin42's Avatar
All aftermarket distributors?
Old Mar 6, 2023
Yes that's all I've been able to find. Two different ones from rockauto. One from AutoZone and one from O'Reilly's
Old Mar 6, 2023
Colin42's Avatar
Go get an oem one from the junkyard. Try to find one out of a wrecked car so you know it was running before.
Old Mar 6, 2023
I looked at all the junkyards near me in the Tampa area. No luck finding any. In fact most the cars are stripped down to a empty shell. Anyone on here have some extra OEM distributors for sale?
Old Mar 7, 2023
Colin42's Avatar
Ebay,
what model distributor do you have? There's two different ones.
Old Mar 7, 2023
Ebay,
What do mean? Like part number? I got only find one part number for this car. 73ud I believe
Old Mar 7, 2023
James Steuber's Avatar
James Steuber is an unknown quantity at this point
change your VVT. Variable Valve Timing. It is below the valve cover on the passenger side of the engine. Auto stores charge over $200 You can get it cheaper online.,it has 3 bolts. Not visible . You have to feel for them . This solved my problem. Hope it helps
Old Mar 7, 2023
I don't believe i this one has vvt. It's a non vtec engine
Old Mar 7, 2023
Colin42's Avatar
​​​​​​​either a Hitachi or Tec distributor
Old Mar 7, 2023
​​​​​​​How can I tell which one it originally had?
Old Mar 7, 2023
don't matter, as long as OEM. hondas are pick on electronics and some electrical things
Old Mar 19, 2023
Yup got a used Honda distributor from a guy locally and the car runs perfect. Very crazy
Old Mar 19, 2023
Re: 2000 Honda Civic d16y7 misfire [solved]
glad that solved the issue
Honda is pick with electronics and some electrical stuff
EKken
Engine Swaps
Jun 4, 2022 11:54 PM
jhaydon90
Nov 14, 2020 04:55 PM
DavidKing
Nov 9, 2017 08:00 PM
