preferred lube for 1.6L camshaft installation
Old Jul 11, 2025
whatchagonnado's Avatar
whatchagonnado is an unknown quantity at this point
Cylinder Head installed and ready to install camshaft and rocker arm train.
Did some reading about assembly and found out I need to lube very liberally the camshaft and the cradle prior to installing the valve train.
There are many videos on you tube suggesting. I would like to put this engine together tomorrow if I can get some responses from this forum. If not then I will hold off until Monday and talk with the maching shop that milled the head.
Thank you in advance .
Last edited by whatchagonnado; Jul 27, 2025 at 10:57 AM. Reason: information no longer needed
Old Jul 13, 2025
Colin42's Avatar
Re: preferred lube for 1.6L camshaft installation
Any asembly lune would be fine. Engine oil at a minimum
Old Jul 13, 2025
oil was what I planned on using but then being my first time, decided to google the procedure. Then read different ways of assembly using different lubes but none mentioned oil. So decided to ask opinions on this forum. I believe I will go with oil as my choice.
partypeepers
Feb 1, 2023 06:35 AM
bachands
May 26, 2021 03:18 PM
Scott89
Apr 14, 2020 12:59 PM
TiggerDX
Nov 17, 2010 06:15 PM
