coolant in engine block 1.6L 2000 civic
Old Jun 23, 2025
whatchagonnado's Avatar
whatchagonnado is an unknown quantity at this point
When I pulled the head, I have coolant to the top of each cylinder. Not inside the cylinders but on outside.
Never saw this before on any engine I worked on.
Looked at three different you tube videos showing step by step removal of head to replace the head gasket and none of the three showed coolant surrounding the cylinders to the top as mine was when I pulled the head.
I was getting P0302 &P0304 misfire codes and lots of water dripping out the tail pipe engine running. Original problem, hose leak, ran out of coolant, engine stopped running. Cooled down about five minutes, drove another two blocks to driveway.
Last edited by whatchagonnado; Jul 27, 2025 at 11:07 AM. Reason: found out this is normal
Eestuck992
Nov 9, 2024 09:50 AM
fvckbg
37
Jun 5, 2016 09:59 PM
vagalati
29
Jan 23, 2013 01:12 PM
swagger9000
Jan 13, 2013 01:03 PM
BigE19
Engine Swaps
39
May 26, 2007 12:46 PM
