crank, but no start.
Old Jun 20, 2025
whatchagonnado's Avatar
whatchagonnado is an unknown quantity at this point
2000 civic 1.6L
tested ignition coil
Primary 1.9 - 2.0 @ 200 setting
Secondary 11.68 @ 20K setting.
Three burn marks on one side, one on other side of coil. I am thinking this coil is toast but I am a mechanical person and not very smart when it comes to using multimeter. would like some advice before I waste money replacing a good coil
Old Jun 23, 2025
Colin42's Avatar
Re: crank, but no start.
Did it run before you took it apart?
Old Jun 25, 2025
yes.
When the engine starter chugging water out the tail pipe, I shut it down and pulled the plugs and rotated the engine several revs to clear the water out of the cylinders. Then trying to start it again, was when the no spark issue showed up.
Old Jun 27, 2025
took to starter, alternator shop. Tested bad. Got new one but in the process of putting engine back together. Hopefully there are no more ignition issues
joshepete
Feb 18, 2023 12:01 PM
old97civic
Sep 10, 2018 03:57 PM
mattej8
Aug 8, 2017 09:28 AM
kookoo
May 20, 2010 11:31 PM
motofabio
Dec 4, 2008 02:00 AM
