2000 civic died while driving, crank no start
Old Jul 9, 2017
mattej8's Avatar
frumpy civic
mattej8 is an unknown quantity at this point
2000 civic EX (canadian Si) 5spd
car died while driving, dash lights all lit up. For the past week I felt a little sputter now and then, but nothing like a misfire.
Now it cranks , but no start.
battery good, fuel good, no spark
recently replaced cap rotor wires(NGK) plugs ignition coil (was getting random misfire code, ran good for months after that repair)
opened the distributor- white char residue inside the cap. ignition coil spring corroded. I'm going to replace the igniter next (and re-replace ignition coil)
QUESTION: Am I missing something? I'm afraid there's some underlying issue and my new parts are just going to die soon.
Praise be to the Honda Sages
Old Jul 9, 2017
Re: 2000 civic died while driving, crank no start
Got any fault codes?
Got a distibutor from a running car you can swap as a test?
A dwellmeter or tach can be used to check for signal that triggers the ignition coil.
If signal is present but no spark, bad coil.
If no signal, something else is wrong.
Old Jul 9, 2017
mattej8's Avatar
frumpy civic
No fault codes
I found a decent used dizzy to test with
Will invest in a meter asap
Thanks ezone
will update soon...
Old Aug 4, 2017
mattej8's Avatar
frumpy civic
Dizzy was the issue. Replaced the whole unit coz I just don't trust the old one, now running good.
Old Aug 8, 2017
eager2learn's Avatar
eager2learn is an unknown quantity at this point
I'm having the same issue. Is replacing the distributor the only way to test if its bad?
Old Aug 8, 2017
mattej8's Avatar
frumpy civic
Got a buddy with a working dizzy? I'd say its the easiest way for beginners. Like ezone said, it's time for us to get meters to test properly.
"Got any fault codes?
If no signal, something else is wrong."
