99 Civic Crank no Start
Old Aug 1, 2022
TheGreatBasin's Avatar
TheGreatBasin is an unknown quantity at this point
Hey all:
To start, I have read through a bunch of posts before coming here for some direction. A little background: I was driving my 99 civic VP on the highway last week when it all of a sudden died. Pulled to the shoulder (harrowing in rush hour traffic) and tried to restart. No dice. Would crank but not turn over. Had the car towed home to investigate. I have spark, injection pulse/RPM signal, timing looks fine. Fuses 13, 31 and 44 are fine. Tested each circuit and am getting power. Ground at thermo housing was clean and tight. Main relay tested fine. I get 12v at the pump while key ON (II) but no power while cranking. Tested fuel pump ground under seat and I have continuity. Relay clicks while cranking but there is no power going to the pump. Still crank no start. I have not tested the ecu yet. Am I forgetting something?
Old Aug 1, 2022
BrotatoChip's Avatar
Super Moderator
Re: 99 Civic Crank no Start
Fuse 31 should have power when ignition is in crank position, it looks like it should be dead all other times. Did you verify?
Old Aug 1, 2022
Hi Brotato:
Yup. Just verified. I only have power at Fuse 31 when cranking.
Tim69304
Oct 9, 2018 11:10 AM
coolbreeze
Dec 31, 2014 07:28 PM
thefinder808
16
Jun 17, 2013 10:05 PM
LauraAshley1989
Feb 24, 2010 10:37 PM
gearbox
Engine start problems
Sep 27, 2006 03:45 AM
