1999 Honda Civic DX manual Crank no Spark
I have a 1999 Civic DX, I bought it as crank no start condition. It had no spark when I tested it, so I got a new distributor and replaced it. It had gas, and air but it still had no spark So now I am here trying to find out what the problem could be.
I checked the Ignition 40amp fuse and it was good.
It does not have a check engine light, but sparkplugs and sparkplug wires are also good. so now I am just confused.
Re: 1999 Honda Civic DX manual Crank no Spark
Try an oem distributor, these cars don't like aftermarket ones. If you still have your old one try replacing the coil and or the igniter. Use oem parts.
I got another distributor from a running 2000 DX and replaced it with mine and it still gets no spark, I think it's an ECU problem or a Cam and crank position sensors.
I also checked the timing and it was ok
QuirkyCadaver
Oct 9, 2021 07:40 PM
Redtubbs
Nov 16, 2020 07:04 AM
captainnasty18
Feb 26, 2018 08:16 PM
acs52
Apr 21, 2007 06:34 AM
