98 civic overheating, no heat, fan working
Hi,
I just drove my car for the first time in two weeks and it started overheating and not blowing hot air. Pulled over and saw a bit of coolant at the bottom of the radiator, and a basically empty reserve tank. Limped it home and lifted it up, put more coolant in it, and idled it for a while. The radiator fan came on when the temps climbed and I couldn't see any coolant leaking, but temps kept climbing and heat still wasn't blowing so I shut it back off. After it cooled down I removed the radiator cap and turning the car on, no coolant or air came out, which I read means it's (probably hopefully) not the head gasket. The top radiator hose gets hot, the bottom one doesn't. Any ideas on what the issue could be?
In case it's relevant, the car doesn't have AC, and I replaced the thermostat about a year ago. It also has a minor oil leak. No idea if the radiator has ever been replaced (doesn't look like it).
Thanks in advance for any help
Re: 98 civic overheating, no heat, fan working
No heat is probably a huge air pocket in heater core.
Is there an external coolant leak?
If not.....The root cause of mysterious coolant loss is usually a failed head gasket.
Update:
Filled it up with coolant and bled it, no leaks I could see. Wasn't overheating and the heater worked. Went for a test drive and gave er the beans, still no leaks and coolant is still topped up, everything looks good. Exhaust smells very slightly sweet, but I don't spend a lot of time inhaling exhaust gases so I'm not sure what it smells like normally 😂 I'm gonna keep some coolant in the car and pray to Jesus that whatever is going on, it's happening slowly enough that it's not a problem for the moment, and I'll take it to a shop when I can.
katelyn85
Oct 8, 2016 09:12 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Running Riot
Aug 10, 2012 10:33 PM
lucy520
Sep 27, 2009 08:56 PM
