Smoking and antifreeze spraying everywhere
Old Oct 6, 2016
katelyn85's Avatar
katelyn85 is an unknown quantity at this point
I have a question regarding my 2004 automatic honda civic. It kept overheating so I brought it to a mechanic. He concluded the fan on the radiator was broke and had to be replaced which is why the car was overheating. He fixed it and since I got it back, there is a lot of white smoke coming out from under the hood now and antifreeze spraying EVERYWHERE out the front grille of my car and even spraying onto my Windshield everytime while I'm driving -- but the temperature gauge doesn't show it is overheating anymore. My mechanic said it was normal to do that for a couple days because he had to bleed out the system to replace the fan. It's been a week and it's still smoking and spraying antifreeze. Could he have damaged something while replacing the radiator fan and what could it be?
Old Oct 6, 2016
mac25's Avatar
Dr Krieger of Modification
Re: Smoking and antifreeze spraying everywhere
***Thread moved to Seventh Gen section***
Humm well it may not be a fan issue, it is also possible if he replaced the entire radiator that he left a hose loose and it is spraying.
Is it wet coolant you see or dry?
Old Oct 6, 2016
katelyn85's Avatar
It is fresh wet green coolant spraying out of my grill whenever I drive it.
Old Oct 6, 2016
mac25's Avatar
Right then it should be coming from either the
-radiator cap
-overflow res.
- or top radiator hose.
First you are going to identify which location it is coming form.
How is the rad. level while cold after a hard rip?
and where in the coolant res. level is the coolant sitting at?
Old Oct 7, 2016
mikey1's Avatar
how is antifreeze spraying everywhere normal?
chances are its spraying out of your overflow/plastic bottle beside the rad by the battery, if so, your head gasket is blown,
the only reason it stopped overheating is because it got filled back up with antifreeze, give it another few days or a week, it will overheat again sooner or later
Old Oct 7, 2016
katelyn85's Avatar
My mechanic said he checked my head gasket when I first brought it in for overheating and the head gasket was fine and it was only my fan.
Old Oct 7, 2016
Colin42's Avatar
he probably doesn't know how to check properly. these cars have a unique way of failing that causes them to pass all the usual tests.
go read this thread:
https://www.civicforums.com/forums/3...reference.html
it explains how to check properly
Old Oct 7, 2016
mikey1's Avatar
this is coming from a guy who thinks coolant spraying on your windshield and all over the engine is "normal"
i think you need to replace more then your head gasket, you need to replace your "mechanic"
Old Oct 7, 2016
Agreed. Mekannik is broken. Replace with a working unit..
Old Oct 8, 2016
mac25's Avatar
lol we need a "like button", you guys are too good =D.
Hondacivic03
Apr 13, 2016 11:04 PM
greenbackz
Apr 2, 2016 01:22 PM
WEG
Mar 22, 2016 11:29 PM
scruffycats
Detailing
Mar 6, 2016 09:31 AM
Red_Chaos1
Mar 3, 2016 10:31 AM
