Misfire, Knock Sensor CEL. Car keeps running when pulling wire
Old Feb 2, 2025
carolderthanme's Avatar
carolderthanme is an unknown quantity at this point
P0303 & P0325 code on CEL. Car continues to run even when i remove the spark plug wire on cylinder 3.
Here is all my troubleshooting I’ve done
Replaced distributor cap and rotor
Replaced wire set
Replaced all spark plugs
Placed wire from 3 onto valve cover with plug in it, it sparks when cranked.
Friend said it was turning funny, did a valve adjustment on it.
Timing was done aswell
Swapped injector from one into three to see if it was fuel. Got rid of CEL for a second but came back after driving around for a second.
Last step I can think of is doing a compression test on it, going to try that when i get home.
Please help!!!
Old Feb 2, 2025
Re: Misfire, Knock Sensor CEL. Car keeps running when pulling wire
Just completed compression test, Leak down test is next. Will keep updating. Any tips appreciated
Mdel93
Jul 8, 2022 05:20 PM
TWright
Sep 2, 2016 10:48 PM
KoiFish
Nov 6, 2015 06:25 AM
sruger
Jan 15, 2015 07:56 PM
mkober
Oct 24, 2004 06:31 PM
