1300k on a rebuild, blowing smoke at high rpms
Old Jun 27, 2022
Lone111's Avatar
Lone111 is an unknown quantity at this point
I've got a 97 civic coupe, d16y8. I did a rebuild on the bottom end, bearings, rings, etc. Haven't had any problems until today. Got off the freeway just fine, started to get into high rpms and noticed a whitish, bluish smoke. No overheating, no.coolant in the oil, no rough idle or loss of power. There is oil residue on the inside of the tail pipe tho. Doesn't smoke at idle. Coolant temp sensor is bad, replacing that today. Any ideas???
Old Jun 27, 2022
FRSam's Avatar
Click Here
Re: 1300k on a rebuild, blowing smoke at high rpms
Did you do a proper break-in? It sounds like the piston rings didn’t seat properly.
Old Jun 27, 2022
Lone111's Avatar
yea did a few heat cycles and kept it under vtech for over the first 500 miles
Old Jun 27, 2022
Colin42's Avatar
Rings or valves. If you did the bottom end correctly then it should be the valves. You can rent a leakdown tester and check. Or rent a compression tester and check using that.
Old Jun 28, 2022
BrotatoChip's Avatar
Super Moderator
Monitor oil level, see how bad it is. 1 quart every 3k miles? 1 quart every 1k miles? Even worse?
MickyGotGot
Dec 4, 2021 02:11 PM
faultlines
Mar 17, 2015 08:50 AM
budbewiser
Jan 2, 2013 06:05 PM
